66 Cutlass throttle assembly
Old Jun 27, 2010 | 11:56 AM
TripDeuces's Avatar
I have a 1966 Cutlass convertible with a throttle cable not the rod and linkage assembly I've seen on other 66's. Did they come both ways or is this the previous owner hacking it? If it is hacked does anyone have a correct throttle for sale?
Thanks,
George
Old Jun 27, 2010 | 12:16 PM
66400's Avatar
6 cylinder cars came eqipped with a cable. V8 cars have rad linkage assembly that differed between manual transmissions and automatic transmissions.
Henry
Old Jun 27, 2010 | 01:11 PM
TripDeuces's Avatar
My car has a 330CI engine in it now. So either it was a 6 cylinder originally or the linkage was removed?
Old Jun 27, 2010 | 06:15 PM
bummerino's Avatar
I have the intricate gas linkage on my 442, compared to the simple rod I have on my 66 ss396 it is space shuttle engineering
Old Jun 27, 2010 | 06:29 PM
Oldsmaniac's Avatar
I parted a 67 with a 330, I may have your part.
Old Jun 27, 2010 | 06:46 PM
TripDeuces's Avatar
Here's the thing. I'm replacing the 330 with a 455 and a Tri-Carb set up. Is it even worth it to get that linkage or should I fabricate a cable assembly? I'm not a purist (/duck) but I would like it to look nice and be functional. Right now I have the Lokar throttle bracket assembly on it and the BG Six-Shooter with three Demons ( I know I'm gonna catch flak with you purists out there)
http://www.facebook.com/photo.php?pi...00000861658073
Old Jun 28, 2010 | 08:56 AM
Oldsmaniac's Avatar
There were 2 types of assemblys. A stick car did not have the switch on it. I believe the factory setup will work with the 330 or 455 with tripower. The actuator rod length may be the only difference.
Old Jun 28, 2010 | 09:10 AM
TripDeuces's Avatar
Thanks for the info Oldmaniac. I'd be interested in that linkage if you find it.
George
Old Jun 28, 2010 | 09:34 AM
Oldsmaniac's Avatar
I need a week and can send ya a picture. It does have the switch on it for the 2 speed Jetaway trans.
defiant1
Feb 4, 2020 08:53 PM
DR_DAN
Aug 2, 2015 02:14 AM
Tallpaul67
Jul 19, 2015 12:24 AM
stratoblues
Sep 1, 2014 06:52 AM
citrusz
May 17, 2011 10:47 AM
