64 starfire running very rich
I've been posting here and there about my 1964 starfire that has an electric fuel pump.
The engine runs very rich, everywhere I go I leave two big black spots in the pavement. The fuel pump pictured is at the rear passenger side. For the time being I'm going to keep an electrical pump, but not sure if I should just get a regulator for this one, or buy one of the pumps suggested by summit racing/Rock auto. If I were to get a regulator for this specific pump, what should I get? If I get the pump suggested by the parts places, would it need a regulator as well. Also should I put in an additional filter before the pump? Other concerns are... I plan to either find a different gas tank, or get the current one restored, because it's leaky, especially if it has a half tank full or more. My concern is that there is sediment in the tank, and I wouldnt want to ruin a new pump. But from what I've read, the pump pictured, is pushing too much pressure. When I got the car, this electric pump was already installed.
Your making a lot of assumptions but provide no facts. What fuel pressure is your pump providing at the carb? Carboned up exhaust system can be from a number of things, running rich is one of them. Like expressed above, pull the tank and see where its leaking, clean and repair, or replace. If there is one quality fuel filter in the system, your covered.
fuel pressure at the carb I do not know. However most of the pumps I've seen that look like this one, the specs say they put out 9 or 12 psi, something like that. But I'm understanding that it needs to be around 4 or 6 max? There is a little fuel present around the top of the carb. Makes me think that maybe the pump is a little much for it. There's no gage. I'm very much a learner here. Can I get a regulator/ gage?
. This is indeed the ultimate goal here. If I were to rebuild the original one, which is completely bypassed, could I still run with the electric setup while it is out? with the original pump system it looks as if I would have to reinstall a return line.
forgive me I'm new st this, but how exactly does this work. Don't they attach to a regulator? How can I measure the pressure without a regulator. If I were to just add a regulator to what is already there, what should I get or not get?
E-Bay has many fuel pump rebuild kits available ;
http://www.ebay.com/itm/OLDSMOBILE-S...5Rl8qz&vxp=mtr
Spray carb cleaner is all you need to clean the parts with . It's not rocket science . I rebuilt my first one at age 14 , without any help .
Try your local radiator shops for gas tank repair , some do , some don't .
oh ok so this thing would be spliced in somewhere closer to the carb?
Yes , you can still run with the electric pump while the fuel pump is out . IF you either make or buy a block-off plate to cover the hole where the pump was . The return line can be temporarily disconnected and plugged . It is a good idea to re-plumb the return line , It may prevent "vapor lock " problems in hot weather .
Last edited by Hillbilllystarfire; June 14th, 2017 at 10:12 PM. Reason: Left out info
