63 Starfire Part Number Help!
might try here. I know Kanter was mentioned above, but here's a link
http://www.kanter.com/drumroto.html#OLDS
Hopefully that helps!
-Jeff
-Jeff
The part # for your front brake drum assembly is 588074 right side, and 588075 left side. those numbers are applicable for all '62-'63 Oldsmobiles regardless of Body styles.
The only difference between left and right assemblies is the Wheel Studs are either left hand thread or right hand thread.
I don't think any of this information is going to help you locate Drums, because all drums out there are after market, but this is what you asked for, so take it for what it is worth......
Kanter does list replacement drums for the 63 Starfire. The reason I was asking about part numbers was that I bought 4 new drums from them, but what I got was nowhere near what I needed. The original drums are composite construction and have that large curved "lip" at the back. The ones they sent me were solid cast iron, weighed a ton, and did not work. They physically fit on the hubs but the center part was almost 1/4" thick, when you put the wheel on the nuts only went part way on the studs and the center hole did not touch the center hub at all. On top of that the front drums did not have the curved part, instead it was a solid built up edge, the 14" wheels hit that and would not go on all the way. When I complained they asked for part numbers to see if they had sent the wrong drums. Turns out these are the only drums they can supply so I will send them back and get a refund. I took my old drums in to be cut and was worried they would'nt have the meat but they turned out OK so I will reuse them after all.
That's what I meant about what is available and that is there is only aftermarket drums around and they don't meet up to their claims!!!
Dead Reckon
Mar 25, 2014 01:02 PM
