63 Dynamic Steering column ground lost
I bought a 63 Oldsmobile Dynamic 88 and the horn does not work. After further testing, I found that the horn button just delivers a ground back to the horn relay, The button shorts out to the steering column when pressed fine. The problem I have is that the steering shaft is not grounded to the chassis. Does anyone know if there is a ground strap somewhere that would ground the shaft. I thought of running a wire from the horn button location down through the column, but turning left and right might not be a good idea. I appreciate anyone's feedback. Thanks.
