61-63 F-85 build
) but I suggest using a Rover 4.6 short block or stroker 215 short block using a 300 crank to build a 260+ HP aluminum motor. Those cars have about a 2,600 lb curb weight, so 260 HP gives you the same power to weight ratio as a W-30. That's an easy number to get from one of those motors. D&D sells bellhousings to adapt a T5 or plates to adapt a BOP transmission.
wildwillie1981
Apr 24, 2013 04:19 PM
