61' 394 cid timing issues
Old Jan 24, 2009 | 07:27 PM
cisco88's Avatar
I just recently did the timing chain on my 55 Olds with a 61' 394 in it. I set all timing marks correctly. Cam at 6 Crank at 12. Right. The reason I change it is, before, I had to retard the timing in order for the veh to start. I was told that the sprockets for the timing chain were made of a material where the teeth break. Anyway, no teeth were broken, but since I was there already I replaced it. Now, I seem to be having the same issue. Help, this is kicking my ***. I've set dist. 180 off to see if maybe I was off installing the timing chain, but still nothing. I have spark, fuel and air. Something with the timing is just not right. Could it be something in the distributor?
Before any of this happend I installed pertronix ignition and the veh ran beautiful. From one day to another this crap started happening. Any thoughts and all thoughts are welcomed. I need your help.
Old Jan 25, 2009 | 02:08 AM
88 coupe's Avatar
Junior Member
Originally Posted by cisco88
........ I had to retard the timing in order for the veh to start ........
Ignition timing? Was this before, or after, you changed the timing chain?
Does the engine still run with the timing retarded?
........ I was told that the sprockets for the timing chain were made of a material where the teeth break ........
Not in a 394. Was this before, or after, the problem started.
........ I have spark, fuel and air ........
Strong spark? Enough to jump a ¼" to ⅜" gap?
Enough fuel? Enough air? How does it react when you restrict (choke) the airflow?
........ Something with the timing is just not right ........
Unless you know that for a fact, it is better left unsaid.
........ Could it be something in the distributor? ........
Could be a lot of things. No way to tell which, without a better description of the problem.
........ Before any of this happened I installed pertronix ignition ........
How long before?
Norm
Old Jan 25, 2009 | 07:32 AM
cisco88's Avatar
Ignition timing? Was this before, or after, you changed the timing chain?Does the engine still run with the timing retarded ?
This was happening before and after I replaced the timing chain. Eng will run if I retard the timing. I believe about 28 degrees. Once I have it running and bring it to time, if i give it gas, it will quit running.
Timing chain had a lot of slack anyway
Does have a strong spark. Plugs are a little fouled from the veh running rich. I did replace them not to long ago.
Enough fuel and air. When I close the choke plate eng quits running.
True
How long before?
I had the pertronix for about 2 weeeks -- I went to flush out my radiator and from then on it started giving problem. Firt the carb was getting flooded and then this. I just don't get it.
Old Jan 25, 2009 | 08:51 AM
Run to Rund's Avatar
I'm suspicious of the pertronix. Can you go back to stock ignition to verify it is not the problem?
Old Jan 25, 2009 | 12:27 PM
cisco88's Avatar
I'm going to be setting the stack ignition in a bit. I should be able to let you know later on today what happens. I was able to get a dist. for $40. Get back to you later on that thought.
Old Jan 25, 2009 | 07:07 PM
cisco88's Avatar
Well, sure enough it was the pertronix. Removed it and put the points back on. Car is now running. Thanx fellas.
Old Jan 26, 2009 | 05:54 AM
Oldsguy's Avatar
Past Administrator
Excellent.
rougebeats
Feb 3, 2010 09:49 AM
bluecutlass
Aug 25, 2009 04:01 AM
cisco88
May 22, 2009 09:50 PM
cisco88
Oct 17, 2008 07:12 PM
