60s air conditioning
Old Mar 30, 2022 | 12:10 PM
dennis_30281's Avatar
Was air conditioning in the 1960s an option or dealer installed
Old Mar 30, 2022 | 12:12 PM
Excuse me...Starfires
Old Mar 30, 2022 | 12:26 PM
RPO C60 Air Conditioning was a factory-installed option
Old Mar 30, 2022 | 01:52 PM
Oldsfan's Avatar
It was also available through the parts department for dealer installation. Option code C60 didn't come into being until mid '60s. Prior to that it was option code N.
Old Mar 30, 2022 | 02:05 PM
The SPECS booklet transitioned from letters to the alphanumeric RPO codes in the 1963 model year. Dealer installation on the Y-body cars was pretty easy, since that A/C was completely divorced from the heater system. I'm not sure how the full size A/C system could be dealer installed without major disassembly of the car.
Old Mar 30, 2022 | 04:49 PM
Thank you guys, now any idea on the number of oldsmobile produced 61-63 with that a/c system
Old Mar 30, 2022 | 08:04 PM
rocketraider's Avatar
Oldsdruid
I've never found any hard figures on it, but it was an expensive option at over $400 so my WAG is 10% or less of yearly production had factory airconditioning.
An aftermarket underdash unit was less expensive, less complicated and could easily freeze you out since they were 100% recirc units. Sears, Penney's, Montgomery Ward and plenty of independent garages installed them by the hundreds and had installation kits for about any American car.
Old Mar 31, 2022 | 05:51 AM
My donor car was an ac car. What a chop job they did on the right side of the firewall to install the ac system. Definitely no structural integrity left.
Old Apr 1, 2022 | 10:33 AM
Your very right about major disassembly Joe. I was wondering about the holes in the dash for th ac vents on each side and after I got the dash out of the car (62 Starfire convertible) I found that Oldsmobile had thoughtfully cast the outline of the holes on the backside of the dash.. With patience and a good size wheel the hole was no big deal and the vents fit perfectly. I'm making my 62 convertible an ac car.
Old Oct 9, 2024 | 05:31 PM
AussieIan's Avatar
The air conditioning bits and pieces from the blower motor and heater box mounted on the firewall forward were removed on my 1968 Olds 98 convertible.
I had the heater hoses and vacuum lines replaced in the engine compartment, but it looks like I will have to take out the dash to replace the diaphragms to get the cabin air vents and the defroster push buttons to work.
Or does it require the entire A/C system to be in place to get the air vents and defroster buttons to work?
Thanks,
Ian
kbdecatur
Feb 26, 2018 04:15 AM
Olds24
Mar 26, 2015 07:05 AM
dc2x4drvr
Nov 10, 2014 06:23 PM
willcynn
Tech Editor's Desk
Sep 2, 2014 01:10 PM
Aedwards
May 31, 2011 08:34 AM
