50 olds 88 carb issue
Old Aug 30, 2015 | 03:01 PM
rusty shackleford's Avatar
303 v8 rebuilt .030 over...AA carb rebuilt....points set, timing set...vacuum advance working... Starts and runs fine...pulls good up till about half throttle then looses power and falls on its face at full throttle. No black smoke out of exhaust... Suspect lean condition.... Any ideas on a solution?
Old Aug 30, 2015 | 05:44 PM
Larry/car's Avatar
Check your float level. Another area could be fuel pump, insufficient volume or rubber fuel line from tank could be collapsing shutting off fuel flow. When you reduce power does the engine immediately smooth out?
Old Aug 30, 2015 | 06:23 PM
I set the float per the Rochester repair manual... Yes , if you let off it runs fine... It Had a fuel pump issue and I rebuilt it with new diaphragms....I do have a small electric pump i may put in line with it to support it... That may increase the volume, if that's the issue. All the rubber fuel lines are new.
Old Aug 31, 2015 | 06:41 AM
Tedd Thompson's Avatar
Check your vacuum advance.If it hasn't been rebuilt lately the diaphragm may have deteriorated to the point you are not getting any advance..... Tedd
Old Aug 31, 2015 | 07:26 AM
Larry/car's Avatar
Another overlooked area is the fuel bowl. I think your car has an in line fuel bowl filter? I have seen where the bowl had contamination that was sucked up into the filter under high fuel flow effectively starving the engine causing power loss. Fuel tank; have you checked it for debris. There should be a fuel pickup filter there. Another question; how did the engine perform prior to carburetor repair?
1yesfan
Aug 4, 2015 06:40 PM
Dead Reckon
Jul 14, 2014 02:35 PM
4speedBench
Nov 24, 2012 05:09 PM
44TEETWO
Jul 1, 2009 02:20 PM
wyteon
Feb 5, 2009 09:13 AM
