which 455 valve cover gaskets, motor mounts?
Old Mar 28, 2025 | 09:34 AM
Bill G's Avatar
All: My limited 'puter skills prevented a search, so i'll put this out, thereby showcasing my lack of knowledge of ....well, most things..
455 Engine is originally from a '75 wagon, built up modestly (sorry, no specifics) but with a somewhat radical cam. Definitely not a racer, but probably more torque than stock.
Engine has low miles since install 17 years ago. Occasional driving, with some long trips, e.g. OCA Nats.
Small oil leak- suspect valve cover gaskets..
Also may have a broken motor mount..
1. Which type/brand valve cover gaskets should I use, if it matters?
2. Is there a choice for type/strength motor mounts? if so, which is preferable?
Hoping to get her to Bowling Green this year.
Thanks for all input.
Old Mar 28, 2025 | 07:27 PM
Can’t go wrong with felpro, however the quality of the install is far more important than the type of gasket. Make sure the sealing surfaces are clean and flat, don’t over torque the bolts.
Stock replacement engine mounts, or aftermarket solid mounts. If you beat on the car, fabricate a limiting strap to keep from tearing up the mounts.
Old Mar 28, 2025 | 07:58 PM
MO Olds 2022's Avatar
Agree with above, especially making sure valve cover itself is flat and even. I did buy Mr. Gasket Ultra-Seal Valve Cover Gaskets 5875 for a set of M/T covers I have and are nice too.
Old Mar 28, 2025 | 09:00 PM
Bill G's Avatar
Thanks for the input..
Anchor 2328 mounts seem like the stock answer for those.
Felpro gaskets..Rockauto shows a cork, a rubber 3/32 (old version), and a 11/64 rubber.
my brother the wrench is not thrilled with cork, but is the thicker rubber the way to go, to be sure, even though they're advised for 'more uneven surfaces'?
joshduty
May 14, 2022 06:43 PM
Cutlass Fan
Jul 10, 2021 02:39 PM
zeeke
Aug 30, 2017 04:27 PM
blackbird51
Jul 10, 2013 11:29 AM
1971
Nov 26, 2011 09:01 PM
