455 olds no oil pressure
Old Jun 9, 2017 | 10:51 PM
78cutlass455's Avatar
Rebuilt a 455 olds and on first start there was no oil pressure. Pulled motor to see if the new oil pump was bad but it seems to be working fine. Pumping oil all over except for to the oil pressure sensor. Not sure whats wrong. Can anyone help me by giving some directions to look in???
Old Jun 9, 2017 | 11:48 PM
Qwik71442's Avatar
Full-time Taxpayer
Check for missing oil plugs in block-two in front at timing chain area and one in the rear in the distributor hole area. In is not uncommon for the rear one to be overlooked and not re-installed when reassembled.
Old Jun 9, 2017 | 11:50 PM
Ok ill check that out. Thanks
Old Jun 10, 2017 | 12:40 AM
Front two are missing. Thanks alot
Old Jun 10, 2017 | 05:39 AM
RetroRanger's Avatar
72 Olds CS
I think one of the front two is supposed to have a hole in it to oil the fuel pump eccentric/timing chain, the rear one by the distributor is also supposed to have a hole in it
Old Jun 10, 2017 | 06:36 AM
Tedd Thompson's Avatar
Yes and I believe the holes are 40 thousands in diameter.... TYedd
RustyOlds
Nov 3, 2016 06:58 AM
72Blazerod
Jan 1, 2015 10:04 AM
foreverolds
Dec 1, 2012 07:07 PM
Railguy
Tech Editor's Desk
Jul 25, 2010 02:36 PM
