455 ci ques
455 ci ques
I just had the mech install new 455 exhaust manifolds in the car and a new carb the old owner never replaced the frame mounts and the exhaust manifolds and left the 350 exhaust manifolds in it and frame mounts bad move.i had the correct ones put in now.the problem they are having is the car idles to lowand wants to stall.they said that the timing is to far advance and it's also burning rich.they said the lifters may have to be torked down i have a set of g heads does any of this makes sense input would be appreciated.is there adjustment on the lifters and where should the timing be set at a little advance or not
None of it makes sence.
How is your timing set and what is your idle speed.
What size is the carb. and what make of carb.
What distributor do you have.
Is the engine stock.
What else has been done to the engine.
I have a HEI dist and the original rockchester 7042251 carb remanufactored.GOING TO HIM TOMMOROW TO HAVE THE TIMING CHECKED.THIS WAS A 455 REBUILT FROM THE BLOCK UP HAS 2000 MILES SINCE THE BUILT,LIKE I SAID IT HAS G HEADS AND A F BLOCK.THE ORIGINAL DIN'T HAVE A HEI DIST.
Where is the initial timing set? With a stock HEI it should be 20° @ 1100 RPM. If they are Chevy mechanics tell them to blow about where the timing is set because they don't have a clue.
The rocker bridges get torqued to 25 ft lbs when the cam is on the low part of bot lobe on that cylinder.
The new motor mounts have changed the static level of the floats ...
Let some air out if the front tires if that doesn't work try over inflating ...
Just kidding...
A dyno tune with some distributor curving might be in order ...
Just kidding...
if the timing were advanced (all thing equal) then the idle would be high and it would be lean. on an Olds there is no adjustment to the lifters if it has the original style rockers and bridges. changing exhaust manifolds would not have a big effect on the idle but you state that they put on a new carb which sounds like the problem if it idled OK before. you should check the timing and anything past that is probably the carb itself
Before i put the new carb in.the car engine use to shake like it does now.i was told if i want the engine to run smooth i may lose horsepower is this true.the original owner said he had a big time northen texas mech build the engine he told me that he thinks the pistons are 30 over and a little better cam then the original.ever since i changed the manifolds wow what a difference in horsepower and performance.from what i can gather the mech has his freind coming by sat to adjust things on the engine he has over 30 years exp building race cars for what he says.what svnt442 said im going to pass the word on about the timing at 20 degrees.thanks for all your input guys with out this website i wouldn't have got my engine right.i tip my hat to all you guys thanks.
![Smile](https://classicoldsmobile.com/forums/images/icons/icon7.gif)
The existing manifolds that were on the 455 engine came of the 350 engine that was the original engine in this car.The gaskets are the same.But for the longest time I started to get exhaust manifold leaks in the gaskets ,after changing them 5 months before.I put up a previous thread.and I was told to put w and z manifolds on.After putting these manifolds on I have increased in horsepower and pick up that I was lacking from the old manifolds.The previous owner said that the 350 exhaust manifolds will work,yes if it was a stock 455 but there were cam,lifters and piston work done over.but side by side the exhaust manifolds chambers look the same but they are different.but the same gasket.The only down side is the existing manifolds pipes were different, The passenger down pipe was 2 1/4 inch and the driver side was 2 inch changing over after the 90 degree bend to 2 1/4 back to the mufflers.The only thing is the exhaust flanges bolted up fine by the drivers down pipe hanges a little lower then the passenger that I was told in a previous thread.But going to change it so the drivers side is 2 1/4 all the way.
Last edited by blueRAYwhale; March 29th, 2010 at 03:05 PM. Reason: "deleted/added info."
