425 v8 I might buy but have questions
I found a 425 v8 that is not too far for me to get and I might get it for my rat rod olds project.But I find that it is missing the harmonic balencer and flywheel.The starter might not be with it either.Would any of you have those parts kicking around.I can make a parts wanted posting but want to wait till I know for sure I am getting the engine.I checked at least one site and these parts did not look all that cheap.But then the ones were more for performance than stock.The listing says the engine ran when parked and it still turns over.I gather from the way it is listed turning over means with a socket and breaker bar lol.I will have to get a transmission as well.But this was the first time i found a 425 near me ither than ones in decent running driving cars.I tend to find 455's listed more than anything.
Just remember that you've got to be prepared to completely rebuild any engine you buy that you can't drive, or to take it as a loss. It's always a crapshoot - you may come out with a great motor, or you may find you've got a chunk of scrap iron, even if it turns over or runs (I bought a running 425 once and found ALL the top rings broken and all of the ring lands, and therefore pistons, destroyed, because an earlier PO had installed the wrong rings, even though the rest of the motor looked great inside and had minimal wear, with good compression in 7 cylinders and mediocre compression in one. The seller had done nothing to the motor other than start and run it twice - he was doing a complete restoration on the Cutlass it was installed in).
I don't know what I should do at this point.MDchanic has a point and if I get the engine I could have to rebuild it.Now I have never done that so I could be looking at anywere from a grand or two or more depending were I take it.
by the way I wondered about your picture or avitar is that a intake set up for two carbs?
SilvrPegasus47
December 25th, 2012 05:27 PM
gardizzle
August 24th, 2010 06:09 PM
