4 speed shifter question...
Old Apr 13, 2010 | 05:07 PM
Eddie Hansen's Avatar
I have a 69 cutlass s with a 4 speed, it has the 442 shifter but it was added, my question is two fold, if the car has a console with the shift pattern did they use a shift pattern on the ball or was it plain?
my second question is more hypothetical, if a hurst olds DID come with a 4 speed, would it have 442 on the handle or would it be a plain hurst handle?
and not related to the shifter per se but if the 69 hurst olds did come with a 4 speed what would the engine code be? I think it was qe for the 455 and auto? would it be just the next letter? like QF
Old Apr 13, 2010 | 05:28 PM
jensenracing77's Avatar
the shifter ball would be plane if the shift pattern was on the console.
Old Apr 13, 2010 | 06:36 PM
wmachine's Avatar
Trying to remember member
A Hurst Olds is not a 442, so there would be no reason to use a 442 handle.
The engine code would be whatever unused letter they decide to use. Guess away!
Old Apr 13, 2010 | 07:04 PM
The plain ball is supposed to be correct, but I bought my '69 W31 from the second owner, who owned it from 1971 til '96 and it had the shift pattern on the ball, and it was very worn, very hard to read the pattern at all, leading me to believe that it was original. It has the pattern on the console as well. I also realize that the ball could have been replaced a couple of decades ago, early in its life and as such was worn over the years as the car has 120,000 miles on it.
Old Apr 13, 2010 | 07:12 PM
hmmm
I will check some more I do not think I have ever seen a plain shifter ****, my 4 speed came with a funny kind of brown shifter **** with the 4 speed pattern on it, not sure if it was the original or not.
ok regarding the engine code was just wondering if there was any methodology to the lettering sequence.
Old Apr 13, 2010 | 07:54 PM
Run to Rund's Avatar
****, black-plain: 65-442-390749; 66-9-409990
Old Apr 13, 2010 | 11:24 PM
stan 65 cutlass's Avatar
same here, black plain ***,shift pattern on console
Old Apr 14, 2010 | 08:59 AM
wmachine's Avatar
2 interesting related items:
1. The '65-'69 manual shift consoles have the shift pattern on the console. I'm guessing the design engineers did not anticipate that the vast majority of the those consoles were going into 4-speed cars. The 3-speed shift pattern is cast into the top plate. With 4-speeds, they drilled 4 holes and attached a 4-speed patterned plate over the 3-speed pattern. Had they correctly anticipated the demand, I would think it would have been done the other way around.
2. '60s 3-speed floor shifts even without consoles did *not* have the shift pattern on the ball.
Old Apr 14, 2010 | 09:08 AM
are they available?
so the 69 to be "correct" would Not have the pattern, and it was either black or White? are these available? and was there ever offered the walnut ****? (similar to the one offered for the GTO).
Old Apr 14, 2010 | 09:18 AM
also interesting the only 65 to recieve a hurst shifter was the 3 speed, all 4 speeds were a saginaw shifter
Old Apr 14, 2010 | 10:23 AM
wmachine's Avatar
More specifically, it was the M14 heavy duty 3-spd manual trans with a Hurst shifter that was introduced midyear in March '65 and was only available (as an option) on a 442. That was the debut of Hurst shifters in production Oldsmobiles.
Old Apr 14, 2010 | 11:27 AM
interesting......
GTO's had Hurst in 64 right? one thing always surprised me about chebbies they never got on the bandwagon, had muncie shifters....
Old Apr 14, 2010 | 01:54 PM
396730 ****, walnut grained, 67-72 AT floor shift
Old Apr 14, 2010 | 05:25 PM
Yes both plain and with the shift pattern are available (Fusicks), but not in woodgrain, white is also available, though not correct, (I have both).
Old Apr 15, 2010 | 02:36 AM
Yellowstatue's Avatar
The shift pattern on the ball is for cars without a console; the console has the shift pattern on it... plain black ball on a four speed w/ console, 10 May 1968!
Old Apr 15, 2010 | 03:00 AM
wmachine's Avatar
Except 3-spds as I noted.
Old Apr 15, 2010 | 11:25 AM
according to the parts book, all 70-2 4 speed cars had the black ball with the pattern, so I guess their console didn't have the pattern on it.
Old Apr 15, 2010 | 11:37 AM
I believe that is correct, trying to get a mental image of my buddies '70 442/4spd. and there is no pattern on the console.
Old Apr 15, 2010 | 06:58 PM
bummerino's Avatar
My friend John back in NY had the exact same car as the one I am building. When I needed to buy the shifter ball I called him, he said that it had the shift pattern on the console ,so the plain black ball is the one I purchased
1968CutlassSupreme
Aug 1, 2014 03:11 AM
marxjunk
Jun 12, 2014 12:34 PM
69CutlassAlex
Feb 9, 2012 05:26 AM
Eddie Hansen
Mar 24, 2009 01:04 PM
olds4life
Feb 27, 2009 08:54 PM
