4 speed case replacement?
Old Jun 11, 2019 | 12:03 PM
matt506's Avatar
With the rebuilding of the transmission to find a 45 mph and above vibration, I have discovered a busted ear on the case. What is every ones thoughts on the beefed up auto gear cases or are the new made original looking ones just as good with the newer metals being used to make them? Matt
Old Jun 11, 2019 | 12:50 PM
jensenracing77's Avatar
I would just have the original one welded. A good weld shop can weld them stronger than original.
Old Jun 12, 2019 | 06:01 AM
jmos4's Avatar
Hi,
I have a Autogear M22W and no complaints, though my understanding is the case is thicker so if you have a M22 the gear noise will be reduced.
I recently saw recast cases the other day, but not sure on quality as never seen in person.
A welder should de able to repair the original.
Regards,
Old Jun 12, 2019 | 06:54 AM
marxjunk's Avatar
a case is only 100-150 for used one..not hard to get...
Old Jun 12, 2019 | 07:01 AM
matt506's Avatar
Thanks guys,
went both ways I bought the auto gear to pound around with and will search for a correct dated one to rebuild for the frame off resto when I get there. Thanks Matt
boc23
Drivetrain/Differentials
Mar 8, 2019 06:21 AM
My2nd 69 442
Oct 22, 2018 11:16 PM
jensenracing77
Jun 30, 2018 04:34 AM
Bfg
Feb 26, 2013 02:05 PM
1968ragtop
Nov 19, 2011 04:40 PM
