4-Jet Mixture Screws
They serve the same purpose as a 2GC or Q-Jet mixture screws. It sets the idle mixture. Best adjusted using a vacuum gauge or by ear if you're good enough. They are for idle only and are non operational once throttle is applied and the primary throttle plates open.
A dual-plane intake manifold will have one set of runners feeding the outside cylinders of one bank, and the inboard cylinders of the other bank. The other plane will be reversed.
The effective firing order is that every cylinder firing alternates between upper and lower plane of the manifold.
The idle mixture screws adjust the idle mix for the two planes of the intake manifold, not for the two banks of cylinders.
