350TH stall converter
Old Oct 13, 2013 | 08:29 PM
quentinnw2's Avatar
I have a 1972 Oldsmobile 350 rocket built mild with comp cam with a 520/523 lift I am running a 22-2600 stall 3.42 posi run good but want burn a tire when I stump on it someone said I need to jump up to a 2800 stall what do you think.
Old Oct 13, 2013 | 10:14 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
What does your current convertor flash at? That is a huge cam for a 350, I hope you have high compression.
Old Oct 14, 2013 | 02:37 PM
quentinnw2's Avatar
Stall
What size stall should I go with do u think a 2800 would be good
Old Oct 14, 2013 | 02:46 PM
coppercutlass's Avatar
Chevy budget Olds powered
I'm running a 512/512 on a 227/234 duration at .050 and for optimum track performance I need a 3000 stall minimum 2400 and that's on the tight side.
455Gbody
Sep 11, 2009 11:47 AM
455Gbody
Sep 8, 2009 11:18 AM
455Gbody
Sep 1, 2009 02:46 AM
Pghstarsky
Oct 29, 2007 08:53 AM
macarthur
Jul 25, 2006 12:46 PM
