350 valve cover gastkets what type?
I've got a 72' Olds with a 350. I am on my second pair of valve cover gaskets. the first ones were cork, the second one's were the rubber type (not sure if that's what they are but the feel like rubber.).
Anyways...I still keep getting annoying little leaks. Is there a certain type to use that works better than the ones I have or is there a certain way the bolts are tightened down.
Any help would be muchly appreciated.
Joe
Joe
![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
Joe
I'd be looking for another problem also, not just gaskets, either of those sets should have done the job. Are you sure you're not under or over tightening them?? I also assume you straightened the valve cover around all the holes, a small dent can make a big leak.
Thanks for the help.
I had this problem with my 350.It turned out that the oil under the intake wasn't getting back down to the pan fast enough and was covering the Holes intended for drainage this caused pressure to build from blow by.I tried every thing for a couple of years.I put sealer on both sides of the gaskets cleaned every thing with lacquer thinner.Nothing worked.And I have aluminium valve covers which are a lot heavier.Oil leaked from every wear,not much at all but every wear. Finely I put a PCV valve in the back of the oil fill tube The oil fill tube goes straight to the pan allowing the pressure to be vented.
Could this be your problem?Did you raise your oil pressure?I've told this story a few times and got no response.
railguy
railguy
railguy
railguy
Thanks very much for the input. I hope you got yours figured out.
fast67vellen2o
November 21st, 2014 10:36 AM
L77F85
Drivetrain/Differentials
16
November 29th, 2013 06:19 AM
Pacecar
August 8th, 2012 04:40 AM
Aceshigh
March 27th, 2010 08:36 AM
