350 block from what!?!?!??!
Old Dec 16, 2020 | 05:09 PM
Kyle's77cutlass's Avatar
Hello gentlemen,
Came across this block but I am having a difficult time in decoding the block. I know it's a 350 but any more of that I cannot figure out.
Old Dec 16, 2020 | 07:07 PM
70W-32's Avatar
I would say '69 350, but that VIN derivative is mis-stamped(doesnt have the factory code) But even if it had a factory id, it wouldnt tell you what type of vehicle it was installed in.
Old Dec 16, 2020 | 07:31 PM
rocketraider's Avatar
Oldsdruid
Service block or industrial engine is my guess.
The casting number on the water pump shelf shows it is a 1968-1976 block. The VIN stamping is different in that there are 7 numbers after the 9 (which I guess means 1969?) instead of the typical 6 numbers after a letter that indicates the assembly plant. So on this block, there is a 1 instead of a letter.
3 = GM division = Oldsmobile
9 = year of manufacture = 1969
1 = assembly plant = "I have no idea, this is usually a letter"
149182 = last 6 digits of Vehicle Identification Number (VIN)
Old Dec 16, 2020 | 07:34 PM
Yes what I was thinking after posted the thread.
Friend of mine bought a marine 455, the same on his too, just numbers.
Old Dec 16, 2020 | 07:38 PM
So with that information, 1 = a marine facility. Interesting. I wonder if there is a listing of marine engine facilities that the Olds community should be aware of?
Old Dec 16, 2020 | 07:44 PM
Yes I caught that as well, the fellow selling it said it was from a 442. I am thinking it's not.
Not sure if I am reading this right, but the information below says it's from 68 to 70 block 395558 2. And if can take the number from the stamp, it's a 69 block
Old Dec 16, 2020 | 07:54 PM
You are reading that right but the information is incorrect. Note in the third line it shows 68-76 350 blocks with the same casting number as the 330 blocks in the first and second lines. This is obviously incorrect. That third line would be correct if the block number was 395558, and the fourth line should have been deleted as it was redundant.
As for that 6th line with 395558 5, well if anyone ever sees one of those, please post a picture of it.
Someone made a lot of errors when copying / pasting that info into the FAQ.
Old Dec 16, 2020 | 07:55 PM
Oops sorry, not the same.
My friends 455 marine engine
Old Dec 16, 2020 | 07:57 PM
Ah note take!!!
Thanks for the correction
Old Dec 16, 2020 | 08:13 PM
Oldsdruid
I'm not familiar with GM Canada numbering, but wasn't the Oshawa plant code "1"?
Old Dec 16, 2020 | 08:45 PM
I think you might be on to something.
See another one forsale and the gentleman states it's an 1969 high compression 350 from the Oshawa plant.
Old Dec 16, 2020 | 08:53 PM
That marine block code is a custom one up there. I think you are right on the Oshawa thing.
Old Dec 17, 2020 | 05:24 AM
rob1960's Avatar
My buddy has an Oshawa built '69 Cutlass S. It's a nice original, 1 repaint, #s matching car. It's all blown apart for a frame off. I'll have him check his engine stamping this weekend. I'll bet it has the 1 for Oshawa also.
Old Dec 17, 2020 | 05:58 AM
beautiful ride
Old Dec 17, 2020 | 06:47 AM
As others have already pointed out, this is a 1969 block from an Oshawa car. Nothing to get excited about.
Old Dec 17, 2020 | 07:54 AM
Not excited, just curious 🤷‍♂️
Old Dec 17, 2020 | 09:14 AM
The generous use of punctuation in the title makes you sound excited...
from what!?!?!??!
815Cutlass1972
May 23, 2020 02:42 AM
72delta88
Oct 28, 2016 11:38 AM
Hawghead
Oct 6, 2014 05:35 PM
Olds350DX
Nov 20, 2009 01:25 PM
70redvert
May 31, 2009 10:47 AM
