330 or 394
330 or 394
which engine do I have?
1964 Olds F85
I thought the engine was a 330, but was informed today that it is a
394.
distributor in rear
filler oil tube front on passenger side
head measures some 14-14 1/4 width
valve cover length 19 in
vin: 844A01217
appreciate getting this cleared up for me
thanks
1964 Olds F85
394.
distributor in rear
vin: 844A01217
thanks
thanks
found the oil pressure idiot sending unit, but not able to get behind the block to
check the numbers, as it is too close to the firewall..
number "23" stamped on the passenger side just behind the alternator.
question: my car has an alternator, but on the dash idiot light, it reads "gen" ?????
thanks
thanks
I see in one of the posts you mentioned why your dash light says gen when you have an alternator. Im pretty sure all full sized oldsmobiles of 63+ all came stock with delcotron alternators and 12 volt coil and such, despite having a light that says gen. I think yours did too if maybe you were thinkin it might've been converted from generator or something.
wr1970
March 29th, 2015 06:36 AM
