3.8 V6 Starting problems
Old Sep 16, 2014 | 04:51 PM
dick91134's Avatar
Talking 3.8 V6 Starting problems
I spent a whole year trying to figure out why my '87 Cutlass Ciera frequently wouldn't start. I replaced the fuel filter, fuel pump relay, fuel pressure regulator, the starter (from trying to start it so many times). Once, I jiggles the wiring harness behind the distributor and it started. When it worked again, I thought I would have to replace the wires which I thought were hard-wired into the distributor. When I pulled on the wires, I was surprised when they unplugged from the distributor. I sprayed WD-40 on the plug and have not had a problem starting for the past year. I hope this info will help someone avoid the frustration and expense when they have this problem.
Dick
Old Sep 16, 2014 | 08:59 PM
RROLDSX's Avatar
Another common issue with fuel injected cars
Another common problem is a stuck fuel pump relay. They are generally located under the hood in the fuse box. Tapping on it can sometimes unfreeze it in a pinch.
http://www.sr20deracing.com/looneytu...lpumprelay.png
Hope this helps.
chasman414
Jun 25, 2020 07:05 AM
bccsrc
Nov 29, 2011 11:08 PM
bebufire
Jun 26, 2011 02:48 AM
VikingBlue
Oct 23, 2010 08:39 AM
justinj
Nov 4, 2008 10:56 AM
