2 barrel to 4 barrel rochester conversion on olds 350
Old Feb 19, 2020 | 04:45 AM
williamwallace11's Avatar
Hey back with another update everything has been going smooth now she starts and idles fine the only issue is at idle when I push the throttle lever it dies out or just has a dead spot where all I hear is air being sucked in. I am thinking it is just a timing issue but it could be something else I switched the jets from #70 to #71 size because I thought it was just running lean but the same problem is still there, anyone who has done this swap what did you do?
Old Feb 19, 2020 | 04:58 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
A stock Qjet for that motor?
Old Feb 19, 2020 | 06:54 AM
yes, it is a stock quadrajet from a 455 from summit racing which said it fit the 350 as well, and I swapped the intake manifold to fit.
Old Feb 19, 2020 | 08:29 AM
OLDSter Ralph's Avatar
Try adding more tension to the Secondary Air Valve. 1/8 to 1/4 revolution clockwise could help.
Old Feb 19, 2020 | 09:30 AM
deadeyejedi's Avatar
Did you get your electric choke hooked up and adjusted properly ?I wouldn’t mess with the timing until you get the carb working correctly .as stated above check to make sure your secondaries aren’t trying to open too soon .
Old Feb 19, 2020 | 09:35 AM
70W-32's Avatar
Have you checked for a vacuum leak?
Unfortunately reman Qjet's can be a whole can of worms, some just never run right.
Old Feb 19, 2020 | 03:50 PM
I’m thinking this could be the issue since it will stay running before the secondaries open and that’s when it gets starved for fuel.
Old Feb 19, 2020 | 04:26 PM
I also when getting the carb apart again found a screw that looks like this that I must have forgotten to put back in, I forgot to mark it with a tag like I usually do, does anyone know the proper location of it?
Old Feb 19, 2020 | 04:28 PM
Sugar Bear's Avatar
Over the check ball for the accelerator pump. This is likely the cause of a hesitation.
Old Feb 19, 2020 | 04:41 PM
Yep, the check ball retaining screw. The accelerator pump won't work properly without it.
Old Feb 19, 2020 | 04:45 PM
I knew it was definitely something important especially since its the accelerator pump, gotta love these threads I would have no idea on my own. Thank you everyone!
williamwallace11
Oct 16, 2019 06:42 PM
VI Cutty
Jun 3, 2017 10:40 AM
tcolt
Mar 16, 2017 09:58 PM
72delta88
Nov 25, 2016 07:49 PM
Bobby455
Sep 29, 2015 05:38 AM
