1974 toronado 455
1974 toronado 455
i picked up this 455 today seems to be pretty complete casting number is 396021Fa number on the block reads 36m702936 , the guy i got it from said it came out of a 1974 tornado, running when pulled.over the next few weeks ill be disassembling it to check out the internals .have no use for the turbo 425 and differential so will post that in the for sale section later on .has the j heads and im assuming low compression pistons.can anyone help me out on the numbers posted?
Not much else to tell. Small valve J heads, low compression, mild cam smog motor. The FA block does not have the provision for a clutch linkage pivot ball, so AT only.
thanks joe. the guy had this thing for 25 years or so, and i guess he was mistaken on the year or perhaps the motor was swapped .said he bought the toro for body parts for an eldorado he had,in any case still a smog motor so will need some work .
The motor must have been swapped, since the trans says it's a 1974. I'd be surprised if many Toro body panels fit an Eldo.
Crank will need to be drilled for pilot bearing.
couple qusetions if you you guys are still with me . the intake manifold on this motor scoops down a bit compared to my other 455 manifold ,im assuming they were built differently. was this due to a clearance issue?is there any advantage to this design ?and whats the reason for the deeper oil pan on this motor?dosent seem necessary on a low compression run of the mill 455.maybe cause they always did it that way!just curious
There's no real impact to the oil pan, but I believe the Toro manifold is considered a performance hit due to restricted breathing. Aftermarket would be best performance, normal F-85 stock manifold would be best cost upgrade. It will certainly work fine as is, however.
SKINNY IL
May 14th, 2010 08:12 AM
