1972 Cutlass Supreme Headers Questions
Original 350 - 4 Barrel
Original A/C
Power Steering
Automatic Transmission on the Column
Everything is completely stock
So I'm hoping I could get a little advice on headers. I've looked at a lot of posts on installing headers, so I am familiar with the problem that websites incorrectly list headers as not available for Cutlass Supremes. I'm entertaining the idea of installing some deep, throaty, sounding headers, but I have a few questions.
What brand or specific set of headers would give me a deep, throaty sound along with being relatively easy to install?
Second, what modifications are usually needed for a header install, I know many people have to move the starter, but anything else?
Am I going to need to move the engine at all or is it just removing parts, installing headers, putting parts back on again?
Thanks for any Help!
Original A/C
Power Steering
Finally, you will have to pull out the dipstick tube. This requires a slide hammer to avoid breaking it off at the block.
I had hooker headers when I had 350 in the car. Didn't need a mini starter, didn't need to move the distribution block. They fit great, but hang little low. Really not an issue if your car is stock height.
I used Hooker 3901 ceramic coated. As far as the install I had the engine out so somebody else may chime in, so they got installed as the engine was being dropped. I know it's a lot easier if you lift the engine couple of inches on each side. Nothing was relocated, stock starter.
had to remove oil dipstick tube on mine.original starter did fit but was nearly touching the header so went with a mini .mine are speed daddy headers from ebay work ok but would not recommend .no matter the header you install your gonna curse a bit
