1972 Cutlass Hood Help
Old March 11th, 2018, 03:05 PM
richeyb's Avatar
Had to remove my hood for a few months and finally went to put it back on today and things don’t look right.
I had four helpers place the hood back to its original position and have locked down with the two front bolts in their original position. However the back bolt hole of the hing leave about a 3/8 “ gap between hood and support. Are there suppose to be spacers or washers between the the two parts? Or do you just tighten down the bolts leaving a gap?
richeyb is offline
Old March 11th, 2018, 03:11 PM
jharsh's Avatar
There should be a spacer for the aft bolts. I believe it is part number 402025.
jharsh is offline
Old March 11th, 2018, 03:53 PM
Looks like this:
oldcutlass is online now
Old March 11th, 2018, 04:03 PM
richeyb's Avatar
Thank you. I’ll see if I can move the car out and search for the spacers... or go hit the store or junk yard
richeyb is offline
Old March 11th, 2018, 06:04 PM
zeeke's Avatar
Advanced auto sells a variety pack of shims very similar to the original. Id have to assume you could get the same from Rock Auto. If you have a body supply near you they would definitely have them.
zeeke is offline
Old March 11th, 2018, 06:42 PM
Most of the Olds restore parts suppliers carry them.
Old March 12th, 2018, 10:00 AM
My experience has been that when you loosen the bolts to remove the hood, the spacers slip out and fall into the gap between the back of the fenderwell and the firewall. They don't always make it to the ground and end up lost forever.
Fun71 is offline
Old March 13th, 2018, 05:46 PM
zeeke's Avatar
Almost every time. On the bright side the fender usually rots out in this location so if you wait long enough you can recoup them with a magnet.
zeeke is offline
Old March 14th, 2018, 04:07 AM
toymobile's Avatar
I have a pair laying in front of me, Where do you live??
Johnny
toymobile is offline
Hurst/Olds 73/74
September 24th, 2016 09:31 PM
guy.graziano
March 21st, 2012 09:32 AM
guy.graziano
December 5th, 2010 12:10 PM
georgiaboy697
July 2nd, 2010 09:23 PM
Eightupman
February 1st, 2010 10:23 PM
Quick Reply: 1972 Cutlass Hood Help
