When I woke up my 1971 Cutlass Conv, I discovered that there was moisture damage under the valve cover & on the head. My plan is to pull the heads & attempt to have them rebuilt/remachined if poss. Anyone have a good shop in NY/Long Island area? If heads cannot be rebuilt any suggestions on a good head solution, aftermarket or otherwise. Moisture damage/blown head gasket Blown head gasket #7 cyl is not firing-no knock
