1970 sport mirrors
Old Mar 16, 2018 | 01:38 PM
Rustbucket2's Avatar
1970 sport mirrors
One parts supplier I use for my 70 cutlass supreme, list sport mirrors for my 70 as being the same up to 77 ! Could this be right, I though the bases where different . If so , I have 73-77 Cutlass sport mirrors setting around. Any thoughts ?
Old Mar 16, 2018 | 02:59 PM
vette442's Avatar
'70 sport mirrors are completely different in every aspect from 71-72 and up mirrors.
Terry
Old Mar 16, 2018 | 03:08 PM
Sorry they have 71 to 77. still way off, right! are the doors the same on 70 to 72's ? will mirrors from a 72 fit a 70?
Old Mar 16, 2018 | 05:16 PM
Sampson's Avatar
Be careful here. There is definitely a difference in 70 and 71 up mirrors. I have 70 mirrors on my 72 Cutlass. I am on my 2nd set of mirrors from TPP. And 1 from OPG. None have fit correctly. They are too large. I took the last one to a local glass shop and they trimmed it to fit. I did not realize the mirror was convex and glued it in backwards. Now I will need to do it all over again.
Old Mar 16, 2018 | 05:25 PM
4speed455's Avatar
70 only for the Cutlass/442. 71-72 Cutlass/442 and 70-82 Camaro/Firebird mirrors will fit the door contours with the correct base gaskets. 73-77 and 78-88 Cutlass/442 mirrors are too long and don't sit level on the 70-72 doors.
Old Mar 17, 2018 | 06:55 AM
That same vendor has (or at least had) the motor mount applications wrong also...
Old Mar 17, 2018 | 04:38 PM
ok. thanks to all with the help. What I need to know is what sport mirrors , will fit on my 70 cutlass doors? other makes, models, years. and still look right.
Old Mar 17, 2018 | 05:05 PM
2blu442's Avatar
The 1971-72 Cutlass mirrors will bolt on just fine, will look and fit well. Olds nuts will know they're different shaped than the 1970 mirrors. But if you don't care about that the 71-72 mirrors are more common and cheaper than the 1970's. John
This link will go to a Buick page that keys out the 71-72 mirrors.
http://www.buickperformanceclub.com/SportMirrors.htm
Old Mar 17, 2018 | 05:10 PM
4speed455's Avatar
71-72 Cutlass/442, 70-81 Camaro/Firebird, 70-72 Skylark/GS 70-72 Lemans/GTO 70-74 Nova all use the same mirrors. Just use the door gaskets from the 71-72 Cutlass/442 which are available new.
https://www.ebay.com/itm/1970-81-GM-...AAAOSwXMBaj2pL
https://www.ebay.com/itm/1970-81-GM-...gAAOSwN5Baj2pQ
https://www.ebay.com/itm/1971-72-Old...kAAOSwqBJXUNcO
Old Mar 18, 2018 | 02:03 AM
Thanks that helps a lot. I have nova, and firebird mirrors setting on shelf. I will get the gaskets.
StickW31
Jun 3, 2011 08:24 AM
montvaleplace
Feb 20, 2011 09:38 PM
1970442
Feb 13, 2011 04:19 AM
frasco
Jan 11, 2011 02:00 PM
Del70
Sep 20, 2010 10:18 AM
