1970 Cutlass Fenders
Old Mar 30, 2013 | 09:47 AM
Chuxter's Avatar
1970 Cutlass Supreme
I guess I've been incorrect but could someone tell me the difference, if there is any, between 70 front fenderss and 71-72
Old Mar 30, 2013 | 11:30 AM
1970 fenders have a flat ridge running along the horizontal inside edge. The 71/72 fenders have 'crumple' ridges
Also the inner liner bolt pattern is slightly different.
1970
1971/72
Old Mar 30, 2013 | 12:26 PM
Chuxter's Avatar
So the exterior appearance is the same? Can The inner fender be made to fit?
Old Mar 30, 2013 | 12:52 PM
Yes, the exterior of the fender is identical. The amount the inner fender might need adjusting is very small so it will fit no problem. It's just mm's of difference in lining up the fender to inner liner, and with the inner liner being plastic?? No problem.
The reason for the structural change was safety legislation. The crumple zone fenders absorb and bend with energy impact. The flat ridge fenders would typically be driven straight back into the cowl/windshield area.
For those who are purist restorers of 1970, the correct fender is worth some $$ even if it needs repairing. ALL the metal aftermarket fenders produced are the 1971/72 style. I don't believe the fibreglass repop fenders/clips have or need the crumple feature, since they're mostly used by track cars to reduce weight.
Old Mar 30, 2013 | 12:55 PM
frankr442's Avatar
Early 71's (maybe only from Framingham?) also have the flat lip. I have two.
Old Mar 30, 2013 | 02:04 PM
True enough Frank. There have been discussions on this site about Olds using 1970 production fenders for some time into the 71 production. The first 71 I saw that had its OEM flat fenders? I did a double take because it was different than I'd been used to on 71/72!
jensenracing77
Dec 2, 2011 09:33 PM
6inarow
Dec 8, 2010 06:59 AM
SoRare
Dec 30, 2009 04:47 PM
dholmes898
Feb 28, 2007 06:47 PM
