1970 455 Alternator
Old Feb 1, 2011 | 11:28 AM
Tucsonbob's Avatar
1970 455 Alternator
What is the proper number that should be on a 1970 455 Alternator?
Old Feb 1, 2011 | 09:50 PM
svnt442's Avatar
You need to be a bit more specific. What car? Does it have A/C? If it's a 442 it's internally regualted. All others are externally regualted.
Old Feb 1, 2011 | 10:16 PM
stevengerard's Avatar
If so its a 1100890, hard to find! and expensive
Old Feb 2, 2011 | 06:09 AM
Tucsonbob's Avatar
It is a 442 with no a/c.
Old Feb 2, 2011 | 03:59 PM
bobb's Avatar
Tucson,
I'm waiting to hear the answer to this one too. I'm assuing a 70 W30 without AC would use the same alternator as a 442 with no AC.
regards,
bob
Old Feb 2, 2011 | 04:19 PM
bobb's Avatar
Tucson,
I did some digging on this site and came up with the following part numbers for 70 442 applications, both are internally regulated, which is why they are unique to 442s only:
1100880 - 37 amp - used w/o AC, rear defogger, or HD alternator
1100890 - 55 amp - used with AC, Rear Defog, or HD alternator
regards,
bob
Old Feb 2, 2011 | 07:05 PM
ROCKET VAPOR's Avatar
Lance
Steven, what is the current $$$ range on a 1100890 alt.???
Old Feb 2, 2011 | 07:39 PM
Tucsonbob's Avatar
Mine is 1100662 with an internal regulator.
Old Feb 2, 2011 | 07:47 PM
70Post's Avatar
Do you have a camera?? If so, post pics of the front and back of your alternator.
Old Feb 2, 2011 | 07:57 PM
Tucsonbob's Avatar
I'll get photos tomorrow. Too cold tonight. Very cold for Tucson standards, down near 20 tonight and no higher than 37 in the day. Snowbirds are not liking this although I did see a few with shorts on today.
Old Feb 2, 2011 | 09:26 PM
You know how that goes, I have heard of folks paying close to 2k for a rebuilt one for that final detail piece of the numbers matching resto, but really I have typically seen them from $400 - $1,200. Its a big range but typically the lower range is for ones with the wrong back or not stamped. The high end is for date matching all correct.
These were installed on 69 and 70 vettes as well so that ups the anti. I'm sure the numbers are different but the open face front end adds to the uniqueness.
Old Feb 2, 2011 | 10:09 PM
70Post's Avatar
Tucsonbob---check your pm's. Prices seem to be ALL OVER the place on these. As Stevengerard states, they can be pretty high but that's primarily from the Chevy demand.
Don't pay up much for the fact that one is rebuilt....that's not massive relative to the overall cost to have done as well as any detailing of the parts, etc.
Here's a 6 spoke open face alternator I recently did (When you read all this talk about "open face alternators" on here people are referring to the front case half and how the case is open all the way to the front edge between each spoke).
The second pic shows a "regular" Delco alternator....not an "open face" design.
Old Feb 2, 2011 | 10:33 PM
wow, looks great Patton. And I agree you can get someone to rebuild it and make it a 63 amp, maybe even higher for around a 100 bucks, so if you can find one for the bottom range or even cheaper snag it. Like all these parts the minute you see one for 350, a month later one goes for 200 then you see one on evilpay go for 800.
Here's a pic of mine. Patton, any idea why mine has two grooves per fan blade and yours as three?
Old Feb 2, 2011 | 11:09 PM
70Post's Avatar
No telling on that. I just checked a few fan blades I have here and I see both styles. Note--on the one I pic'd it's not 3 ridges on every "blade". Don't know if those ridges were put in to stiffen the blades or for something else. Maybe they decided they needed additional stiffening on the wider blades??
So many oddball variations on these parts. I would say that your fan blade is correct for a '70 as it matches one I have here...2 ridges per blade all the way around. I don't state that as being "determinitive" or exclusive...I'm instead confirming that yours matches a known original I have.
Although....upon closer inspection yours appears to have the super rare "prominent trailing edge tab" on the widest blade!!!
Old Feb 3, 2011 | 10:34 AM
Lance
Thanks Steven, it looks like I will have to take out a second loan on my house just to get one
I'll start keeping an eye out for one though
Old Feb 3, 2011 | 01:32 PM
yep, glad I kept that and the master brake cylinder, though I did let my original radiator go - so I have been keeping an eye out for that and the ever elusive 66-70 cruise control stalk - that's the fun of this game always something to look for, fix or tweak.
Old Feb 3, 2011 | 03:52 PM
bobb's Avatar
Hi Guys,
Rocket......when you go to buy one of these open faced alternators make sure you check the BACK of the alternator. I've seen a number of these on Ebay that have an incorrect back half casting. The correct one has raised heat sinks over the regulator, not just slot holes in the casting. For the price people are asking for these alternators you should get an entirely correct one, not just a correct open faced front.
later,
bob
Old Feb 3, 2011 | 04:42 PM
here is what mine looks like for reference
Old Feb 3, 2011 | 05:10 PM
Lance
Thanks for the info Steven and Bob.
I'll save these photos for furture referance.
Old Feb 3, 2011 | 08:11 PM
70Post's Avatar
Another shot of the back....larger for more detail:
Old Feb 3, 2011 | 08:36 PM
2blu442's Avatar
I was recently talking with Steven about these alternators. Here's pictures of the one I've stashed away until I'm ready to use it. The mounting hole on the back is closer to the 6:00 O'clock position than the one you guys have. For those of you who know much more about this than me, any ideas why this would be in a different location? John
Old Feb 3, 2011 | 09:01 PM
Tucsonbob's Avatar
So, what do I have here?
Old Feb 3, 2011 | 09:26 PM
bobb's Avatar
Tucson,
I can't make out the 6th digit, but if it's a "9" as in "1100696" then it was stock on 66 Vettes with 327 and 427 engines rated at 350,390 and 425 hp when ordered with the K66 transistorized ignition. That's the good news. The less good news is it was also stock on Novas, Chevelles, and other Chevys that year.
Now.....you know how much we frown on people putting Vette parts on their 442s.....so please sell that alternator to some Vette nut for a ridiculous amount of $$$$ and get the right one for your car. Sheeeesh....the nerve of some people.
Have a great night,
bob
Old Feb 3, 2011 | 10:42 PM
70Post's Avatar
Must be one of the '69 versions...they had the slight differences in the finned back half. August 26, 1969 date code but that could have landed on a '70 car I would guess....who knows for sure?? The alternator I posted the pic of the back of above is also 1100890 55A and has a date code of "9L5"....so it's a bit later build....November 5, 1969.
I'll volunteer since nobody seems to want to take on this heavy responsibility......Why don't all of you with these open face alternators, finned-back alternators, etc send them to me and I'll sort this whole mess out for everyone.
442mark
Sep 30, 2017 01:06 PM
charlierogers
Oct 14, 2011 09:44 AM
esisson
Nov 24, 2009 03:10 AM
marzgtp1
Aug 31, 2009 08:19 AM
marzgtp1
Aug 21, 2009 01:31 PM
