1970 442 overflow bottle
Old May 24, 2023 | 08:23 AM
Zr1bandit's Avatar
Do you have to relocate the washer bottle on a big block 1970 442 if you are going to install a radiator overflow bottle ?
Old May 24, 2023 | 08:54 AM
70W-32's Avatar
Ive seen the washer bottle still in the factory position with an overflow bottle. I guess it would depend on what overflow bottle you use. Are you installing a recovery type system, or just an overflow catch bottle
Old May 24, 2023 | 08:57 AM
70W-32's Avatar
Old May 24, 2023 | 09:08 AM
Zr1bandit's Avatar
was going to use the factory style bottle from The Parts Place
Old May 24, 2023 | 10:25 AM
70W-32's Avatar
Just curious, are you filling your radiator to the correct level. I have a 70 SX, and it never looses coolant. Only reason for my catch can is that the racetrack requires it.
Old May 24, 2023 | 01:19 PM
Zr1bandit's Avatar
was keeping it near the top. Seems to be less prone to spit up when it’s a couple inches down from the top. Not sure what the correct level is. ???
Old May 24, 2023 | 03:26 PM
70W-32's Avatar
Should be about 3 inches below the cap. If you overfill it will spit out the excess due to expansion. The factory tanks have a Fill To indicator on the outside.
Old May 24, 2023 | 03:55 PM
Zr1bandit's Avatar
ok. Thanks, good to know. Will try running it that way.
Old May 24, 2023 | 05:02 PM
The OEM radiator will tell you.
Old May 24, 2023 | 05:06 PM
70W-32's Avatar
Howd you get that picture to load? I tried the same picture and I kept getting an error that I was over the allotted size.
Old May 24, 2023 | 05:11 PM
What's your file size and format? This is a JPG that's 1.0M.
Old May 24, 2023 | 06:31 PM
Zr1bandit's Avatar
Thanks guys for the info.
Old May 24, 2023 | 07:26 PM
70W-32's Avatar
what's your file size and format? This is a jpg that's 1.0m.
71.5kb
the text that you have entered is too long (97622 characters). Please shorten it to 10000 char.acters long
This is the error
received, there is no text involved, just the JPG
jopa
Jan 30, 2022 08:41 PM
Cbudge
Jan 8, 2021 08:03 PM
huskalade
Apr 18, 2018 05:31 PM
Zr1bandit
Feb 7, 2017 04:27 PM
Johnd
Jul 13, 2015 05:41 AM
