1969 vs 1970 442 Coupe Rear Seat Frame-Bottom
Old July 8th, 2023 | 03:13 PM
Bryan Burch's Avatar
Are they different assemblies? I see Dynacorn makes a reproduction for 70-72.
Old July 8th, 2023 | 05:23 PM
Loaded68W34's Avatar
The 70-72 holiday coupe rear seats are narrower than the 68-69 to accomodate the change in arm rest, but a post coupe should be the same. 72 uses a slightly different seat bottom than the earlier years. The outside ends are notched where the seat goes under the upper cushion to clear the 72 style retractable seat belts.
Old July 8th, 2023 | 10:41 PM
Thank you for the info. I'm re-covering the seats, but the bottom is covered in rust scale. But the real issue is two welds are broken. I really need a welder, or a cheap seat frame.
Elephant_Engine_Ernie
January 1st, 2021 05:22 PM
scrappie
May 30th, 2019 08:33 AM
Eaglesfan
June 29th, 2014 07:12 AM
Johnd
March 8th, 2014 03:31 PM
junior supercar
Cars Wanted
November 23rd, 2012 06:15 PM
Quick Reply: 1969 vs 1970 442 Coupe Rear Seat Frame-Bottom
