1969 rearend
1969 rearend
I have a 12 bolt rearend out of a 1969 cutless s I had the motor tuned up at the shop and guy said that if I put 390 gears in it that i would have more power but then i have heard other people say put 273. I have check on the 390 gears and I was told i could no longer get those gears with pose track. So i need your guys help could you give me you input.
The gear ratio has nothing to do with the amount of horsepower the engine makes, however it can help you use it better. Lower numerical gears give you top speed and fuel economy with slower acceleration. Higher numerical gears give you better acceleration but higher engine revs on the freeway and lower gas mileage. Your call as to which is more important to you. Be aware that parts and gear sets for the Type O are hard to find, so you may not have a choice.
you also have to be mindful of what carrier is in the rear end now.
Olds made 3 different carriers each designed for specific gear sets
you can't put a 3:90 gear on a carrier that originally had a 2:56 - 2:73 series or the 3:08 - 3:23 series -
you need to find which carrier you are working with before you start to swap out gears unless you're planning on going aftermarket carrier also .
Rgds
Rgds
Just to expand a little, as the ratio gets lower numerically, the pinion gear gets larger. This requires the ring gear to be further away from the pinion centerline, hence the different carriers. Since the 2-series carrier has the ring gear furthest away, you can space the ring gear for a 4-series gear set. The opposite is not true, since you can't have a spacer with negative thickness.
If gas milage is what you are looking for go with 273 gears. If you want more get up and go 391 fits the bill . I am currently running 323 gears which is a happy medium . Good for all around in my book. The first thing I would reccomend is that you see what gear you currently have and go from there.
Yes it does. It's still a Type O. This is a source of confusion for many people. Twelve bolts on the cover does not necessarily make it a twelve bolt axle. It's the bolts on the ring gear that matter.
1BAD68"S"
Drivetrain/Differentials
December 29th, 2007 09:05 PM
66JET
January 6th, 2007 02:33 PM
