1969 442 Core Support
Old October 23rd, 2024 | 11:11 AM
Crimson@69442's Avatar
Are the radiator supports at the bottom where the radiator sits different on a Cutlass S vs a 442? Also, what color did the factory paint the core support. Satin black?
Thanks!
Old October 23rd, 2024 | 07:51 PM
2blu442's Avatar
The 2 and 3 row radiators used one size, then the 4 row used a different size for the bottom and top radiator supports/saddles. Both were available with the Cutlass or 442 so its not specific to the model, but how the car was optioned.
Old October 23rd, 2024 | 08:36 PM
70Post's Avatar
To add to what John said....the large core support itself is the same no matter what. It's the "spot-welded-on" parts that differ like the radiator saddles (2) on the lower part of the support.
A satin gloss black paint or maybe slightly glossier would be appropriate for the paint finish. I'm assuming satin is the "middle" of the gloss range b/n flat and gloss. I wouldn't go any flatter than a satin finish.
Old October 24th, 2024 | 07:28 AM
I was under the impression that Olds underhood black was a 60% gloss.
Old October 24th, 2024 | 06:51 PM
My car is A/C and has the big radiator, I'll drill out the spot welds and switch the saddles. Looks like Eastwood has a quart of satin black that should work. It looks like the factory did not primer the core support before painting?
Thanks for the info guys!
Abbydog
May 3rd, 2024 07:14 AM
Flgaurban06
September 3rd, 2012 12:44 PM
rroobble
January 19th, 2011 06:49 PM
SMOSLEY
June 6th, 2008 01:33 PM
