1967 belmont
Old Mar 11, 2012 | 06:22 PM
campoy72's Avatar
1967 belmont
I just bought a 1967 belmont 425 four door it still has the original engine I was told.How can I check that and what type of engine this car has.Engine casting number is 399244D,on the right cylinder head it has R027607, i found 1974w39 stamp on the cowl can somebody help me
Old Mar 11, 2012 | 06:43 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Well, that's certainly a 425. If the car still has the protect-o-plate with the owner's manual, the engine number on it should match that number from the cyl head.
Post up your cowl tag info and we'll see what else it says.
By the way, it's a Delmont 88.
Old Mar 11, 2012 | 07:13 PM
campoy72's Avatar
67 Delmont
Thankyou sorry about my spelling. Can I build this car with a cam with the specs of maybe the 442 455.It doesnt have any manuals or plate.I was doing some reading and found this engine is a high compression,10.25 to 1it has a four barrel carb.it supposed to have 360 hp and 470 torque.Do you know what the 442 had
Old Mar 11, 2012 | 07:18 PM
Yeah - get out and look at the script on the side
... on the right cylinder head it has R027607...
R 027607, with no letter after it, corresponds to the 26,607th 425 made in 1967, equipped with 10.25:1 compression and a 4 barrel carburetor, rated at 365 gross HP / 470 foot pounds torque. It was the standard 98 engine, and optional on the other full-size lines.
Welcome to Classic Olds.
Got any pictures???
Old Mar 12, 2012 | 06:53 PM
campoy72's Avatar
67 belmont
This is the numbers that I got from the plate.10C 67-35639 314 C6D and to the side was BG377
