1966 Olds Cutlass 330 intermittent running
Old Jun 2, 2018 | 02:30 PM
rroth01's Avatar
From: Orion Township Michigan 30 Miles North of the Murder City
I have a problem with my 66 Oldsmobile 330.Engine was rebuilt 4500 miles ago.I dont have the Luxury of driving it that often.Havent driven her in 2 years.She will start and run fine for 5 to 10 minutes and shut down.I have drained the tank and added 5 gallons of 100 Octane.Added another 5 Gallons of Ethanol Free 90 Octane.I have changed the Fuel Filter .New Fuel Pump...And Ideas .Thanks in advance Ron Roth
Old Jun 2, 2018 | 03:22 PM
TripDeuces's Avatar
Is it an original 66 Quadrajet?
Old Jun 2, 2018 | 03:31 PM
rroth01's Avatar
Yes rebuilt by Sparkys...
Old Jun 2, 2018 | 03:37 PM
Start with the basics, check to see if your getting fuel after it dies by pumping the throttle and looking down into the carb. Make sure your getting spark.
Old Jun 2, 2018 | 04:38 PM
TripDeuces's Avatar
I'll just throw this out there. 1st Gen Quadrajets were notorious for flooding. The fact you didn't mention a rich odor probably means Sparky's addressed the known problem. That's a good thing.
Inside the bowl is a passage that connects to the fuel inlet passage, it's at 90* to the inlet passage. There is a tower like structure with a brass pressed in plug. I had my carb apart several times before I realized that was where the leak was. Many rebuild kits have an aluminum plug to stake into the hole.
Old Jun 2, 2018 | 06:42 PM
Sugar Bear's Avatar
"Start with the basics, check to see if your getting fuel after it dies by pumping the throttle and looking down into the carb. Make sure your getting spark."
X2
Good luck!!!
Old Jun 3, 2018 | 06:03 AM
When you drained the tank, did you flush it out? Replace the inlet sock on the pickup? The symptoms sound like the classic "sucking crud against the inlet sock" problem.
Also, temporarily plumb a fuel pressure gauge to the carb inlet and mount it where you can see it while you drive. What is the pressure doing when the car stops running?
Old Jun 3, 2018 | 10:22 AM
If it does it while idling, disconnect the fuel tank and pull from a red can into the fuel pump and that would eliminate any issues with the tank from consideration if it still does it. If it stops, then it might be tank dropping time.
Old Jun 3, 2018 | 12:02 PM
TripDeuces's Avatar
My fuel sock collapsed on my 66 in the tank. Didn't starve it completely but the power drop was noticeable
Old Jun 9, 2018 | 06:30 PM
rroth01's Avatar
Thank You all..My Fuel tank is in Very Rough Shape..Lots of Sediment .I thought I bought an exact replacement online .Not even close..My Car scores very High..Any ideas where to find the correct Replacement .Someone told me a 1966 Chevelle would be compatible..
Old Jun 9, 2018 | 06:35 PM
rroth01's Avatar
Thank You Sir..My Tank has seen better days.My Car scores very High ..I bought what I thought would be a simple replacement.Not even close..2 Rear Vents and the Filler Tube can be reached..Is there an A Body Replacement Chevrolet Buick Pontiac..Thank You in Advance .Ron Roth
Old Jun 9, 2018 | 09:33 PM
RandyS's Avatar
There is not a direct replacement for a 66 Cutlass tank. Everything sold for a 66 has 2 vent lines. I had to buy one for a Chevelle, then swap the filler neck from my Olds tank to the Chevelle tank. They neck is soldered in, you can DIY it if you have experience sweating copper joints.
cougla
Jun 8, 2018 08:22 AM
tschie
Oct 9, 2016 10:02 PM
Arrowstorm
Jan 28, 2016 06:56 AM
66-3X2 442
Oct 16, 2014 02:57 PM
Jonmueller1
Sep 21, 2013 03:29 PM
