1966 Cutlass 330 OEM throttle linkage options
Old Feb 25, 2014 | 06:05 PM
Larrys'66's Avatar
I am looking to find advice on options for linking the 1966 Cutlass 330 throttle linkage with an Edelbrock 750 with a Torker intake and a TH 350 trans. The linkage could be reused and the kickdown switch could just stay in place but it would be good to know what others have done to replace it.
I would appreciate other ideas and pictures if they are available. The motor should be in the car by Sunday if all goes well with the brake line conversion.
Thanks....
Last edited by Larrys'66; Feb 25, 2014 at 06:39 PM. Reason: Added detail on carb and trans...
Old Feb 25, 2014 | 09:01 PM
RAMBOW's Avatar
Ben
Buy a lokar replacement pedal & cable system, then it will hook up like every other TH350 setup, and you can actually properly adjust the WOT position.
If you haven't put the engine in yet, its the perfect time to do it while you have easy access to the firewall.
Old Feb 26, 2014 | 11:15 AM
Larrys'66's Avatar
Thanks RamboW
I had a look the Lokar stuff at Summit Racing, very nice stuff and pricey.... Nothing specific for an Olds though and I would need to confirm if the linkage mounting location on a Chevelle is the same. I know a guy who has a '67 Chevelle, so at least I have a car to compare to.
Maybe I can fabricate a linkage component to take the place of the kickdown switch but I still need to think about the trans.
Old Feb 26, 2014 | 12:47 PM
Thanks....
I bought linkage parts from McMaster Carr and fabricated my own when I installed an Ebrock on my 62. See this thread for photos. Scroll down to post #19 in that thread.
Old Feb 26, 2014 | 01:19 PM
All you need is to adapt the throttle rod to the carb and a detent cable with the mounting bracket for a chevy to adjust the kickdown.
Throttle bushing and grommet:
And something like this:
Old Feb 26, 2014 | 04:22 PM
jag1886's Avatar
Here is how I did it it on my 65, should be real similar on your 66. I removed the stock arm and made a new one using the stock rear pivot a piece of 1/4" metal rod and a new pivot on the front end, all you need all you need is a 1/4" fine thread die to make this and you can bend or make it any length needed.
Old Feb 26, 2014 | 04:29 PM
ROBZ442's Avatar
This is what I did on my 66 except instead of a rod end I bent a 90, welded a washer in place, and drilled a hole for a cotter pin. Looks very similar to a stock unit. I like this one much better than mine. As long as you thread the rod far enough you will have plenty of room to adjust the WOT position.
Old Feb 26, 2014 | 04:32 PM
I think his bigger concern was how to hook up the T350.
Old Feb 26, 2014 | 04:36 PM
ROBZ442's Avatar
Sorry about that, I was speed reading, and my slow reading is bad enough. Your answer was correct and would work just fine.
Old Apr 21, 2014 | 06:48 PM
Larrys'66's Avatar
Now that the car is running and driving, it is clear that the stock throttle linkage doesn't have near enough travel to fully open the carb. I get about 3/4 open before my foot is to the floor.
I will take the advice on this thread and work on altering the linkage to see if I can find my secondaries. It was kind of funny to cruise the highway at a top speed of 50 MPH as the mini vans went whizzing past.
Old Apr 21, 2014 | 08:48 PM
I reached under the dash and bent my gas pedal arm up a hair at a time until it opened full throttle.
Old Apr 22, 2014 | 03:32 PM
jag1886's Avatar
There is two ways I know of, if your car has always been an auto there is an adjustment below the switch pitch switch on the bottom link that you readjust for more travel and if you hook your carb linkage into a lower hole on the carburetor arm you should be able to shorten the linkage which will give you more travel.
I had to do both on my 65 to get full travel.
Old Apr 23, 2014 | 04:23 AM
Larrys'66's Avatar
Thanks Jag1886, I will look more closely. I bead blasted and painted the switch pitch linkage while out of the car and totally missed the adjustment. I did remove the stopper on the linkage to get a little more travel.
L69
Sep 24, 2014 03:33 AM
clubw29
Dec 28, 2013 06:49 PM
Jul 5, 2012 09:34 AM
1k442
Feb 2, 2012 10:45 AM
therobski
Apr 2, 2010 07:33 AM
