1962 Starfire engine angle
Old Jan 31, 2024 | 05:52 PM
dennis_30281's Avatar
1962 Starfire
At what angle/degree should the engine/transmission be when in the engine bay swinging from the overhead hoist and bolted to the frame at the front mount.
The reason I'm asking is that I am installing my Ross 394/700r4 conversion might have to do some tunnel work plus make a new crossmember.
Old Jan 31, 2024 | 06:18 PM
Charlie Jones's Avatar
Phantom Phixer
Read this thread;
My New TH400 Compared To Slim Jim - ClassicOldsmobile.com
You will need to modify the crossmember as well as modify the rear motor mounts to fit.
I don't think he had to modify the floor pan, but it was close.
61 and 62 are the same underneath,
Old Jan 31, 2024 | 08:20 PM
Hi Charlie,
Do you know the angle that the eng/trans sets in the engine bay. I had heard it was 3 degrees from level
Old Jan 31, 2024 | 09:26 PM
major tom's Avatar
New but Olds
If the tail shaft is 3 degrees down, the rear end pinion should be 3 degrees up. This assumes the chassis is fully loaded at ride height on a level surface.
Old Feb 1, 2024 | 05:06 AM
I reinstalled the rearend in the same position as I removed it. So when I install the engine I can set the tail shaft at 3 degrees from 0 degrees and be in the ballpark. We'll give it a try.
Old Feb 1, 2024 | 03:07 PM
CANADIANOLDS's Avatar
absolutely not. that would destroy the shaft and U joints in no time
Old Feb 1, 2024 | 07:02 PM
major tom's Avatar
New but Olds
Really, please explain.
93celicaconv
Jul 28, 2023 04:19 PM
Supernice88
Dec 7, 2021 06:25 PM
1961&1962Starfire
Sep 27, 2021 11:47 AM
Dutchman
Sep 15, 2014 02:11 PM
hurstoldz
Aug 2, 2012 03:01 PM
