1961 Olds 88 Dome light help
Old Jan 31, 2015 | 08:38 PM
oldrelics's Avatar
I can turn the dome light switch on and off at the dome light but nothing happens, but when I open each door separately the dome light comes on.
At the lamp there is a black wire always hot. And a white wire.
I can't figure out whats going on.
Should it come on with the Courtesy light switch on the dash?
Help!
Old Feb 1, 2015 | 08:11 AM
D. Yaros's Avatar
Had one back in the 60's, but can't recall what did what. It is possible the courtesy light swithch only turns on the dash/foot well lights. Look in the owner manual. It should tell you what the switch does/does not control.
Old Feb 1, 2015 | 08:30 AM
Is the switch on the dome light dirty or corroded?
Old Feb 1, 2015 | 10:44 AM
oldrelics's Avatar
I don't have the owners manual and the GM sevice manual says nothing.
Old Feb 1, 2015 | 10:45 AM
oldrelics's Avatar
I took the switch apart and it looks fine.
Old Feb 1, 2015 | 11:14 AM
Well, then I'd say go through the wiring schematic in the Service Manual and see if you can troubleshoot each point in the circuit to see where the problem is.
These can be tough.
tindrumstoo
Jul 13, 2011 04:50 PM
68Tom
Mar 28, 2009 07:11 AM
68Tom
Mar 26, 2009 07:56 PM
gerlof_1
Jan 24, 2008 12:19 AM
HAFROD
Jan 22, 2008 05:12 AM
