What is the 1960 a/c clutch pulley bearing number? Where to get a new U.S. bearing? Will this bearing fit all years os A5 compressors from 1955 through 1961?
Thanks. I saw the part number in the parts book but did not think it was an actual bearing number but it is. Found a nos bearing for $225.00. Too much $$$$ for me.
However i did research the number a bit more and came up with some interchange numbers.
I will post what i end up doing.
Thanks. Ron
906952
a/c A5 compressor pulley ball bearing
- new departure
- shields on both sides
- 1958 thru 1961
- most gm a5 compressors
Brand:GM
Part Number(s):906952
Product Name: Ball bearing
Inside Diameter : 20 mm,0.7874 in
Outside Diameter : 47 mm,1.8504 in
Width : 23.81 mm,0.9375 in
Cross Interchange Parts
Brand Sku Type Relevance
SKF995204 Ball bearing Direct
NSN3110-00-450-9686 Ball bearing Direct
NSN3110-01-117-3522 Ball bearing Direct
NDH995204 Ball bearing Direct
NDHZ995204 Ball bearing Direct
ACDelco
TIMKEN
5204KZZE Ball bearing Indirect
DT Components
Precision Seals & Bearings 5204KZZE
