14x6 Wheel fit Front Discs
I picked up a set of 14x6 steel wheels for my '70 and before I drop them off at the painters, I want to make sure these wheels will fit a car with front disc brakes. Anyone know for sure?
Probably not, '70's would have used a 14 X 7 wheel that did fit disc brakes...but there is a 14 X 6 wheel for '69 (795??) that will fit disc brakes...put the wheel on the hub and see what you have for space...there is a thread on this but I don't know where to look
They are just the standard 14x6 steel wheel that Oldsmobile used back in '70. They came off a '70 SX with 4-wheel drums. I've got a feeling they won't fit but want to make sure first. I'd slap one on the car but it's in storage for another month.
SOME 14x6 wheels will clear factory discs (all bets are off on aftermarket kits). When disc brakes were first introduced in the late 1960s, GM used different wheels on the disc brake cars. 14x6 wheels were factory available with discs, but the contour on the backside is different from the drum-only wheels. I can tell you from first-hand experience that the 14x6 SSII wheels will clear factory disc brakes.
There also *may* be letters/numbers stamped along the outer part of the outermost part of the rim on the inboard side of the wheel. These numbers can help identify the wheel.
Being that we're on this topic, and not to hi-jack, will 14x6 JK HG by valve stem, and also K3 by stem fit a disc car....factory of course?
Also, what might have a 14x5 JJ , HJ K3 by stem , come off of?
Thanks in advance.....
I believe all 14" x 7"s will fit factory discs.
I agree I don't think so either. I have a 72 front disk set up on my 67 and had to go with 15" Cragars.DSCN2135.jpg
I stand by my statement that a 14 x 7 *should* fit. It definitely would if it was an Olds wheel.
Well you know I believe Elephant you have a point, there maybe some 14 inch that will work, however what is the goal? This may be taking the path of least resistance which I take somtimes because I am dealing non-original Olds cars anyway, get 15 inch Olds/GM rims and end of discussion. Just my 2 cents....
Again, there are different contours on the backside of the wheel. The portion of the outer rim that drops down towards the center of the wheel does not need to be centered front-to-back. This is the fundamental difference between the drum-only 14" wheels and the disk-compatible 14" wheels.
Once again, I have personally run 14x6 steel wheels on my factory A-body disk brake cars.
