0ldsmobile swap 445
Old Mar 11, 2013 | 08:04 AM
Kenwon Lamont Jones's Avatar
Wink 0ldsmobile swap 445
i have a 83 olds delta 88 4dr , i put a olds455 in now iam looking for some headders for the situp cause some one bent my flanges i was told so i always had a major exhaust leak , but im trying to fix it with out spending money i didnt need to spend or buying the wrong parts
Old Mar 11, 2013 | 08:31 AM
Do you have headers in the car now? I'm not aware of anyone who makes BBO headers for the 1977-1990 B-body cars. Some people use the G-body headers, but that requires removal of the two bolt-on chassis braces that run from the crossmember to the side rails. I'd hesitate to remove these because GM typically doesn't install parts that aren't needed. I suggest you use W/Z exhaust manifolds instead.
Old Mar 11, 2013 | 08:43 AM
it might be regular 307 manifold on it now im not sure what it is just trying to fix the exhaust leak and free up some bbo power if possible
Old Mar 11, 2013 | 09:04 AM
i was think the same thing a long time ago but just started to look at some headers thinking it might work but like you said i think thorton is my safest bet thanks
Old Mar 11, 2013 | 09:17 AM
Lars's Avatar
i have not axually done this but i hear our b bodys are very similar to 73-77 a-bodys. useing heeaders for these years will work.
Old Mar 11, 2013 | 12:47 PM
They are, but the difference is the bolt-on braces I noted above. These are what make headers nearly impossible.
Old Mar 12, 2013 | 12:20 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I understand your point and concern about the metric delta braces.
GM Won't spend a penny more than they have to it seems.
However...
I have beaten the snot out of a few of these cars with the front braces removed for over 10 years, and can honestly say, the rear spring perches will bend, or the rear frame rails will rot out long before the engine cradle suffers permanant damage.
I'll try and find pictures of the bent rear perches. In my opinion, they should have braced that area better.
Bennie Sanchez
Jun 22, 2012 10:57 PM
69442
Dec 24, 2011 05:31 AM
cutlasssupreme71
Feb 7, 2010 08:13 AM
StickW31
Jan 21, 2010 08:12 AM
70OLDS442
Nov 18, 2007 01:51 PM
