MSD Weights and Springs Help
Old May 2nd, 2015, 09:23 PM
Senior Moment Member
z11375ss's Avatar
Anyone running an MSD pro billet that has what they feel is the correct bushing and spring rate? Something on a setup similar to mine. BB, 10.5 to 1, Edelbrock heads, 525 cam 3.70 gears in a Cutlass. I'm just trying to figure out where to start.
z11375ss is online now
Old May 2nd, 2015, 09:43 PM
Chris J's Avatar
I have nearly the exact set up on my 68 442. My distributer was setup by the machinest who built my motor and it works gteat i will check the springs and weights tomorrow and let you know what the setup is
Chris J is offline
Old May 3rd, 2015, 05:59 AM
Chevy budget Olds powered
coppercutlass's Avatar
I thoght the pro billet had a chart with specific curve tunes based on bushing/wheights combos that msd has already engineered ?
coppercutlass is offline
Old May 3rd, 2015, 11:37 AM
z11375ss's Avatar
They do. It's on the box that was thrown out with the weight and bushing set. Not by me. I just ordered new ones.
Old May 3rd, 2015, 03:38 PM
No PDF file on msd's web site . New ones should have what you need.
Old May 3rd, 2015, 05:00 PM
Chris J's Avatar
I running 1 silvrr heavy and 1 blue light. If you have a fax send me your # i would be happy to fax you the sheets
Chris J is offline
Old May 3rd, 2015, 05:29 PM
z11375ss's Avatar
My Kingdom for a fax machine! I have one at work but don't plan on going in any sooner than I have to. I will contact you with that number in the near future if the springs and bushing set doesn't come with the charts. I will let you know if that happens so you don't think I just blew you off. This is more for my Vette than for the Cutlass. They both have the MSD setups in them. The Cutlass runs like a scalded dog and I'm very happy with it. I do want to fine tune it however. My Vette just kind of lays over under 3k rpm in 1st. I want to fix that. It should be roasting the tires. Thanks a million my friend.
Old May 3rd, 2015, 05:54 PM
Chris J's Avatar
If you like send me your address in a pm and i would be happy to send you a copy if you would like me to
Chris J is offline
Old May 4th, 2015, 08:06 PM
johnnyjaws's Avatar
I have a 1976 stingray for sale 49000 miles on it 4 speed needs a paint jod 1st 5700.00 obo gets it
johnnyjaws is offline
Old May 4th, 2015, 10:10 PM
z11375ss's Avatar
Hey! No hijacking of the threads! JK
DoubleV
February 8th, 2015 12:06 PM
f-85
August 9th, 2013 09:22 AM
Ken'sConvertible
July 22nd, 2013 12:30 PM
RetroRanger
September 12th, 2011 09:57 AM
Redog
May 15th, 2008 06:21 AM
Quick Reply: MSD Weights and Springs Help
