1966 98 battery draining HELP
Old Nov 4, 2013 | 02:52 PM
66BOAT's Avatar
My meter shows a .28 amp battery drain. All the lights, etc. are off. I have pulled fuses to find the circuit to no avail.
I am thinking it could be the convertible top motor as this is powered without the ignition being on. How can I test it. I do not know where the fuse is, maybe someone out there can give me some advice.
When the motor is running, my meter shows 15+ volts across the battery terminals, so the charging system seems to be ok. When I disconnect the generator lead, the .28 amp drain still shows on the meter.
Thanks for any advice
Old Nov 4, 2013 | 03:22 PM
rootney's Avatar
Good technique so far.
Try pulling the connector on the voltage reg. with the car not running, see what your ammeter reads.
I had the same problem. after replacing with a more reliable solid state unit, problem gone.
George
Old Nov 4, 2013 | 04:10 PM
Do you have an aftermarket stereo and amp? Trunk or hood light?
Old Nov 4, 2013 | 06:01 PM
66BOAT's Avatar
Stock radio, trunk and hood lite off.
Could this car have an alternator? There is no voltage regulator on the fire wall like there is on my other identical car.
Old Nov 4, 2013 | 06:09 PM
Do you have a picture?
Old Nov 4, 2013 | 06:17 PM
It'd better have an alternator.
It would have originally come with an externally regulated alternator, but that may have been replaced with an internally regulated unit at some time.
I agree - take the alternator and regulator out of the circuit and see if the drain stops - could be a bad alternator diode.
Old Nov 4, 2013 | 07:18 PM
66BOAT's Avatar
I originally thought the car had a generator, shows you what I know.
Yes. The drain goes to zero when the alternator is disconnected. Apparently an internally regulated alternator was installed in the car. The wiring harness on the fire wall is taped up where the lead to the regulator was.
Hopefully a new alternator will fix the problem.
Thanks to every one for all the help.
Old Nov 5, 2013 | 12:26 PM
stellar's Avatar
stellar
If it is a 1 wire alternator, it may be normal depending what type of 1 wire it is. If it is a volt reading and not an amp reading on a 3 wire internal alternator it may be normal. Is the battery going dead? How long does it take?
Old Nov 6, 2013 | 12:16 PM
66BOAT's Avatar
I changed out the alternator and it is now charging 14.5 plus/minus volts, and the drain is gone.
Thanks for all the help !
Old Nov 6, 2013 | 12:43 PM
Fantastic! You're welcome!
Old Nov 6, 2013 | 12:48 PM
Well done.
Old Nov 6, 2013 | 12:53 PM
rootney's Avatar
Anytime.
Glad to help.
George
Joffroi
Dec 16, 2012 08:45 AM
78olds_ponce
Jan 10, 2010 05:58 PM
projectheaven
Jan 27, 2008 06:13 PM
pinky
Nov 5, 2007 01:59 PM
branemi
Jul 20, 2007 09:46 PM
