Why is my fuel gauge reading this way?
Old Jul 7, 2013 | 05:43 AM
CuttBoy's Avatar
I have a 1969 Cutlass S and the fuel gauge is reading this when I start it up.......Any help would be greatly appreciated.
Old Jul 7, 2013 | 05:56 AM
Because the connection between the gauge and the sender has been broken.
Welcome to Classic Olds.
If you search the forum, you will find that this question has been answered a number of times before.
A quick glance shows information here, here, and here.
You need to check to be sure that the sender wire is connected to the back of the gauge, then check to be sure the wire's not broken as it passes from the back to the front, then check that it is connected to the sender, and that the sender is properly grounded.
Old Jul 7, 2013 | 06:16 AM
CuttBoy's Avatar
I apologize for asking a repeat question (Im a newbie) and havent quite figured out how to use this site to my advantage. I really appreciate the info and i think you have solved my problem. Again your help is greatly appreciated.
Old Jul 7, 2013 | 08:44 AM
Here's a link, and there is link halfway through that gives a full explanation.
Good luck.
https://classicoldsmobile.com/forums...tuck-full.html
Old Jul 10, 2013 | 05:42 PM
kbass72's Avatar
My 70 was the same way. I was told it was most likely that the sending unit was bad. Bought one off evilbay, installed it and now i know how much gas i have.
JPMDaddy
Jan 31, 2020 04:01 AM
W-27
Apr 3, 2014 08:36 PM
HitTheHole
Nov 18, 2013 02:46 PM
jpaulwhite
Jun 26, 2012 02:59 PM
Dan K
Dec 13, 2011 11:03 AM
