Need a turn signal cam for 70 Cutlass Tilt
Old Apr 10, 2013 | 05:10 PM
Bluemeanie's Avatar
Does anybody have one?? I need one pretty bad,..and it seems nobody makes a repop for the Tilt Column.
Thanks!
Old Apr 10, 2013 | 06:17 PM
Id be willing to bet the turn signal switch, cam, and most other parts are the same up until the late 80s. As long as the column is a tilt without cornering lamps and other fancy stuff, the parts should be the same. Can you post a picture of the part your looking for?
Old Apr 10, 2013 | 06:39 PM
Bluemeanie's Avatar
Here's the part in question. As you can see the part of the cam above the turn signal switch is broken off. It makes for a sloppy turn signal, won't stay on in the left position, and feels like its going to break every time I use it.
Any help or input is appreciated...
Old Apr 11, 2013 | 02:52 PM
pcard's Avatar
70 Cutlass SX
Check with your local GM/Buick dealer - I have has success with them. As Matt says these columns had a long production run, and were used in many different models. The GM computer system will tell you which dealer in the country has one. Take a printout of the photo, as well as a copy of the CSM page showing the part.
BTW - I am not sure if the tilt column has a different switch than the regular.
If you find more than one please let me know.
Good luck, Peter
Old Apr 11, 2013 | 03:14 PM
1970supremevert's Avatar
turn signal cam?
here you go??rock auto under body interior
File Type: jpeg
Old Apr 11, 2013 | 05:46 PM
The turn signal switch is different between tilt and non tilt, only in the length of the wires. They will function the same. There is also a difference between cars equipped with cornering lamps.
Old Apr 11, 2013 | 05:48 PM
pcard's Avatar
70 Cutlass SX
This is what is needed. Not sure what if the RA item is the same. It looks like it may be the same but from the reverse side.
This is also at RA:
http://www.rockauto.com/catalog/more...857&cc=1217472
Cheers, Peter
Old Apr 11, 2013 | 06:33 PM
turn signal cam
I could be wrong , but I think you can replce just the cam depending on which "design" you have
Old Apr 11, 2013 | 06:48 PM
Bluemeanie's Avatar
Wow,..Thanks a lot for all the info fellas. I really appreciate it! I'll have time to get this figured out tomorrow and order some parts. I'll let you all know how it goes...
costpenn
Jun 24, 2015 10:38 PM
67 delmont conv.
Aug 1, 2012 07:28 PM
OLDSmobility
Oct 3, 2010 12:04 PM
StarfireFan
Aug 28, 2009 03:30 PM
ewingr
Nov 14, 2007 09:18 PM
