Fuel sending unit ground
Old Jan 16, 2013 | 12:36 PM
m371961's Avatar
Post Fuel sending unit ground
I do not see where the fuel sending unit ground wire attaches to the unit itself. Me thinks it may have been corroded and broken off.
If that's the case, anybody got any ideas?
Old Jan 16, 2013 | 12:59 PM
hookem horns's Avatar
Replacement unit for an A-body had it already attached to the top of the sender. Also had a stud for the positive lead.
Old Jan 16, 2013 | 05:59 PM
White_Knuckles's Avatar
Hmmmm, therefore your gauge is nada, no-function i.e. no longer with us??
The sender is likely self-grounding as hookem mentions. Are you solving for a gauge issue or just a general question? You should read variable resistance from the sender output pin to ground. It's just a float operated, variable resistor varying ohm values to the gauge as the float moves. If the needle goes to max, usually the send wire is open.
Old Jan 17, 2013 | 12:21 PM
m371961's Avatar
I know that all electric guages are just analog meters that measure variable resistance to ground. I just see no output pin or spade connector for the ground.
Ground the wire from the guage, goes to zero. Try grounding the fuel line nipple or the sender body and not working. Guess I pull it and see whats happening.
Now where the heck did I put that new lock ring and seal?
Who has the M.A.W. helmet? I need it to resist replacing the gas tank.
Oldskool84
Oct 10, 2014 06:21 AM
pfergy600
Oct 4, 2014 05:29 PM
JPMDaddy
Oct 20, 2013 08:21 AM
Flye
Apr 2, 2009 11:09 AM
