72 cutlass radio wiring
Old Jun 5, 2011 | 06:52 PM
Wolf's Avatar
Looking to put a cd deck in my 72 cutlass, anyone have a wire diagram? did a search can't seem to find anything?
Old Jun 5, 2011 | 07:14 PM
rocketraider's Avatar
Oldsdruid
To install a modern radio in your car, about the only thing you can really use is the yellow 12V switched power wire that powered the original radio unit. Everything else- memory power, speaker leads, antenna- needs to be wired separately.
If you don't want to cut up the dash, I think someone is repopping factory 8-track player housings and setting them up to mount DIN chassis stereo units.
Old Jun 5, 2011 | 07:25 PM
There is a single plug with three wires that supplies the power:
Yellow - ACC hot
Grey - Dash lights (from dimmer)
Black (or was it brown?) - Ground
Depending on what sort of radio, if any, was in your car from the factory, it may have a single speaker in the middle of he dash, one in front and one in back, or two in front and two in back. Each type will have a different wiring harness and different wires, but you probably don't want to use them.
Old Jun 6, 2011 | 05:44 AM
As stated above, I used the original power wire from the stock radio, and tapped into the fuse box for my constant 12v memory power. Tied the gound wire to chasis.
bsambo59
Aug 13, 2013 05:47 AM
dancutlass
Oct 2, 2012 02:49 AM
dallas6778
May 21, 2007 02:18 PM
TIREGUY
Dec 16, 2006 04:10 PM
