Gauges, gauges who's got the best gauges
Old Dec 12, 2009 | 08:29 AM
citcapp's Avatar
Ok, so I am researching gauge packages for my 48 Olds. Kind of like the antique gold look. 6-gauge setup 3-1/8" face for the speedo and tach and the smaller 2-1/16" for the oil, temp, gas, fuel
So far have looked at VDO, Autometer, and Classic Instruments in both the electronic and mechanical. Almost too much information.
Please share you opinions and experiences with me on quality and on the electronic verses the mechanical
Thanks in advance for the input.
Pat
Old Dec 12, 2009 | 08:53 AM
redoldsman's Avatar
Proud Viet Nam Veteran
For that car, i would try and put together Stewart Warner gauges. That is just because they are about as vintage as you can get. When I was you back in the 60's, I could not afford them. I have a trio (oil, vacuum and water temp) for my 72 Cutlass. The electronic may be a littlle better and easier to install in some cases than the mechanical but I see nothing wrong with the mechanical. Just my opinion and I know whatever you do is going to be top notch.
Old Dec 14, 2009 | 07:58 AM
Blk71SX's Avatar
Stewart Warner has been around forever.
Auto Meter would be right with SW for quality of product.
I've used both and have no problems with either
The mechanicals are more difficult to install, especially the water temp because of the larger hole in the firewall required. But the mechanicals are simple in operation.
Stay away from ammeters, go with a volt meter. It's much easier to install and much less dangerous to the electrical system
Old Dec 14, 2009 | 09:44 AM
Oldsguy's Avatar
Past Administrator
Originally Posted by blk71sx
stay away from ammeters, go with a volt meter. It's much easier to install and much less dangerous to the electrical system
yes yes yes, listen to the man!!
Old Dec 14, 2009 | 10:52 AM
citcapp's Avatar
The ammeter is not something I would use in any case. My question is more to the quality of the gauges by brand. I have done a lot of research and Classic Instruments seems to come out on top. I was looking for input who might be or have installed these manufactures. I currently use autometer gauges in my 57 so I am familiar with them.
Old Dec 14, 2009 | 11:10 AM
Oldsguy's Avatar
Past Administrator
OH sorry Pat, I realize you wouldn't and my response sounded like I was harping to you. Just thinking about this thread being read in a year or two and wanted everyone to know how much safer a voltmeter is.
Tedd Thompson
Oct 7, 2014 07:59 AM
57olds
Ninety-Eight
May 24, 2007 05:07 AM
jchargu3
Body work
Feb 9, 2007 02:12 PM
OldsMotion
Nov 16, 2006 04:45 AM
Redog
Nov 15, 2006 09:27 PM
