Horn Issue
Old Jan 26, 2024 | 08:42 AM
Phoenix8990's Avatar
Horn Issue
69 Cutlass. My horn periodically honks when moving the steering wheel. I removed the horn button and it will still do it with steering wheel movement. I figure something is making contact but don't understand where it could be. There is a plastic sleeve that goes through the hub to prevent that. Any thoughts?
Steve
Old Jan 26, 2024 | 08:55 AM
You need to find where the horn relay is picking up a ground. It can be a frayed/chafed wire, the plastic insulator sleeve, etc…
Old Jan 26, 2024 | 04:00 PM
It's got to be somewhere in the wheel. AGGH, I have had this wheel off so many times, I guess one more time won't kill me.
thanks,
Steve
Old Jan 26, 2024 | 04:02 PM
While were at it. Joe had said that the steering column has a mark on it that should be at 12:00 to be centered. If you expand the pic you can see my mark is kind of at an angle. It almost looks like it wasn't what the factory would have done. Is that common and should I trust it?
Steve
Old Jan 26, 2024 | 04:04 PM
"Periodically honks" You have a tilt column it looks like. Does it honk periodically when the "column" is being shifted up/down or when the steering wheel is being rotated...or both?
Old Jan 26, 2024 | 04:11 PM
72455's Avatar
1972 U code Supreme
Does the horn work normal when you push the button?
Old Jan 26, 2024 | 07:55 PM
Steve
In addition to any other problems you may have, I can tell you that your steering wheel hub isn't indexed properly on the column. The post where the pin comes up through the hub should be at about the 10 o'clock position with the wheels straight ahead. If it isn't indexed properly your turn signal won't cancel correctly. The lock plate on the steering column under the hub should only go on the shaft one way, which constrains the post to the correct location. You've got problems in that column.
jettech67
Jun 7, 2022 03:48 PM
QS442
Feb 19, 2020 07:21 AM
69CutlassAlex
Jul 28, 2014 06:54 AM
hawks70
Nov 18, 2013 03:23 PM
rmoths
Mar 30, 2013 12:15 PM
