Rally pack guages
Rally pack guages
I have 1969 Hurst/Olds I'm changing the old gauges (fuel-oil-temp) (tick tac guages tach & click) for rebuilt ones the rebuilt ones don't come with the resistors so I resoldered the old resistors on the rebuilt gauges they aren't working properly
So Guys I need to know the proper resistance or values of the original resistors
Or is there something else I'm missing in the loop? I replaced the oil & temp sender on the engine block the wiring is perfect and ohms out so no breaks or grounds it's baffling
Need your help badlyThanksalsmith787
