R71S Delco Energizer Classic Battery
Old May 23, 2022 | 10:46 AM
tnswt's Avatar
'70 4-Speed W Machine
I contacted Turbostart another potential candidate for making the Oldsmobile R71S Delco battery. They didn't say no, but they weren't promising either. In my opinion, Battery Central Mall and Jim's Battery are complete failures when it comes to a source for a reproduction battery.
Old May 23, 2022 | 11:49 AM
rocketraider's Avatar
Oldsdruid
They're missing an opportunity. Big block Oldsmobile, Buick, Pontiac, 70-72 Chevy pickups and Cadillac all use that battery.
Old May 23, 2022 | 01:37 PM
Hairy Olds's Avatar
Shoveling Snow
Old May 23, 2022 | 01:48 PM
tnswt's Avatar
To me, it's puzzling they went to the trouble to market the R59, but stopped short putting out the R71. Like you say, I would think there would be plenty opportunity for demand.
Funny, I called JEGS, where I first saw the R59 by this particular producer. The tech guy at JEGS told me there had to be demand for the R71S battery. I said to him that's why I'm on the phone; I want to purchase one. I think my response went over his head.
Old May 23, 2022 | 04:15 PM
briane's Avatar
I have a R71S that came with the purchase of my '69. What are the tell-tale signs to distinguish a reproduction from a Delco original or service replacement?
Old May 23, 2022 | 04:21 PM
tnswt's Avatar
I imagine if you have to give your battery water it is not of the AGM type.
Old May 23, 2022 | 04:27 PM
tnswt's Avatar
rocketraider I sent your post to Turbostart and the following is the reply. In all fainess though I suspect his data is skewed because I'm willing to bet people are buying the R59 because it is so much easier to obtain than the R71S. It would be better for the community if there was an alternate source for the R71 rather than having to deal with Jim's Battery Manufacturing.
I did provide pictures.
Old May 24, 2022 | 03:34 AM
briane's Avatar
Regarding the reproduction R71S, were they all AGMs? Were there ever any made in traditional lead plate?
I believe the R59 reproduction is more popular than the R71S as there were many more applications. The Chevelle SS with the standard top post battery for example. These must be small manufacturing operations as their product lines are so narrow.
Old May 24, 2022 | 03:46 AM
Tri-Carb's Avatar
Shop - BCM (batterycentralmall.com)
$355.00--All are made to order. My last battery took about 4 months.
Old May 24, 2022 | 06:10 AM
tnswt's Avatar
I'm aware of BCM. I've been dealing wtih them since Nov 21, 2021; that's when I ordered a R71S battery. And I still don't have it. The whole purpose of soliciting Turbostart is that an additional supplier could possibly create a bit more stability in the marketplace.
Old Sep 14, 2022 | 09:58 PM
FStanley's Avatar
they were made by Antique Auto Battery here is what their web site is now: https://www.antiqueautobattery.com/
where are the "antique batteries"?????
Old Sep 15, 2022 | 02:39 AM
Tri-Carb's Avatar
As far as I know, these guys are now the exclusive sales outlet:
https://batterycentralmall.com/?s=R7...&product_cat=0
Old Oct 19, 2022 | 02:22 PM
FStanley's Avatar
Call em up and see where it goes....
Old Oct 19, 2022 | 03:56 PM
VC455's Avatar
Barely Registered
Originally Posted by FStanley
Antique Auto Battery...web site is now: https://www.antiqueautobattery.com/
That was always the Antique Auto Battery web address; however, I understood Antique Auto Battery quit the business.
By the writing style and word choice in the articles, apparently non-native speakers of English purchased the web address.
I read one of the articles (H7 vs 94R) and the number of errors and the extent of misinformation was laughable. There was apparently zero research done, because H7 and 94R are the identical battery size--H7 being the European designation and 94R the BCI designation.
Cross that website off your list.
Old Dec 1, 2024 | 05:58 AM
Tri-Carb's Avatar
The company that builds and sells for Battery Central acquired the assets of Antique Auto Battery. Based on my own personal experience if you can find a topper that works on a modern AGM you are better off. You may need to rough up the AGM case and paint it black. Use lacquer or an adhesion promoter.
Old Dec 1, 2024 | 08:48 AM
66-3X2 442's Avatar
The R69 is actually the correct battery for the 66/67 442's. The tar top was used in early 66 and that was the change over year to the R69. The difference between the R59 & the R69 is the R69 is one inch taller,otherwise the same size. As far as the repo AGM's go, it was hit or miss for me. I got tired of trying to keep it maintained so I bought a black case DEKA and put a topper on it.
Old Dec 1, 2024 | 04:04 PM
FStanley's Avatar
the repro R71S batteries were not that great they just made a case and then put a smaller battery inside. For reference look at the pics here. doesn't last long term..
https://classicoldsmobile.com/forums...roject-167057/
Old Dec 1, 2024 | 04:18 PM
VC455's Avatar
Barely Registered
To their credit they no longer pretend this is a full power battery. Their published battery specs show low weight (39 lb) and low Cold Cranking Amps (530). Those are the specs of a small battery.
ddd777
Sep 12, 2022 08:19 AM
Jon442
May 10, 2021 07:31 AM
4speed455
Mar 12, 2021 10:31 AM
Neil Morrison
Feb 28, 2020 06:35 PM
VikingBlue
Feb 11, 2012 10:24 AM
